AC-Clutch not working!!
Old Aug 23, 2002 | 06:11 PM
naijai's Avatar
My the clutch on my compressor seems to be dead any one got any advice for me on how to fix it or if i have to take it to a shop? cause it was working then all of a sudden stopped and please no flames lets be civilised
Old Aug 23, 2002 | 09:11 PM
Miasma's Avatar
it may be that there is no pressure and when there is no pressure the clutch will not engage as a failsafe
Old Aug 25, 2002 | 10:38 PM
Chunger's Avatar
My other car is a Hybrid
Check your A/C fuse... If it blows again, there is a short or the A/C is drawing too much current and you'll need to replace the compressor.
Old Aug 26, 2002 | 01:20 AM
96_vqmax's Avatar
i would check the freon first to see if there is freon in the line,if no,you got a leak,if yes,then i would disconnect the wire (the plug)on the ac compresure,then try to connect a wire to the plug on the ac compresure SIDE,so it is long enouge to the battery pos side,i than touch the wire to the bat pos side,very quickly on and off a few time to see if the cluch engage or clicking,if not,then you probably had a bad ac clutch or comp,then i would bring it to the shop to check it out,hope this would help,good luck.
Old Aug 26, 2002 | 06:32 AM
Miasma's Avatar
it is good thinking, but i would not do that, too risky...
take it to an ac shop that specializes in this kind of thing
Old Aug 26, 2002 | 10:41 AM
Chunger's Avatar
Try the fuse/power first... if there isn't any power, the clutch itself will not engage... If it engages and the air is not cold (enough) then you don't have enough refrigerant (our cars don't use freon).
Old Aug 26, 2002 | 11:12 AM
Miasma's Avatar
not always true, our compressors are variable displacement which means that the swash plate angle changes dynamically. the compressors go bad frequently because the swash plate angle can no longer be controlled. I have had 3 compressors with this prob. I need to buy a new compressor not a reman.
Old Aug 26, 2002 | 12:34 PM
Chunger's Avatar
I'll stand corrected as I'm no expert on refrigeration, especially on our cars... i was going with experience from my old supra.
mvm062
Nov 30, 2020 09:00 AM
kmitchel
Oct 30, 2015 10:12 AM
Maxima30
Sep 7, 2015 06:13 PM
iflexsteel
Sep 2, 2015 08:04 AM
Hailstatejig
Sep 2, 2015 06:52 AM
