Has anybody had this happen???
Old Aug 25, 2002 | 12:45 PM
Mr Cranman's Avatar
Last night me and my friends were racing on the street. We pulled beside a 01' GT and we both motioned and when the light turned green we went at it. Got a good jump and shifted into second hard and was in the lead then heard a lot of clunking. Took it home to see what was going on and the driver side CV joint snapped in half at the shaft like in between the two boots. And this is a rather new CV joint like bought like last year around November or so. I should be able to get it replaced by NAPA but I was wondering if anybody else have broken a CV joint before. I've had CV joint fail pretty recently but this is the first one that has just broken. Just thought I would post to see if anybody else has had this happen or might know what caused this to occur.
-John
Old Aug 25, 2002 | 12:51 PM
Miasma's Avatar
ouch, that sux, never had it happen, but always wondered if it would\could...
Old Aug 25, 2002 | 02:50 PM
bullseye's Avatar
Was your recent replacement CV really new? I thought most CV joint replacements were reconditioned/rebuilt units. Sounds like it wasn't tempered properly, and/or it stress-hardened and, snap. I've never had one snap, but then again, I've never had much more HP than stock... Good luck.
Old Aug 25, 2002 | 04:45 PM
MaximaMan's Avatar
I'm not to familiar with what is being talked about in
This post, could someone post a pic or give a littel better explaination of this object? Apprieciate it!
Thanx,
Brandon
Old Aug 25, 2002 | 05:24 PM
99maxi's Avatar
did u at least win??
Old Aug 25, 2002 | 05:36 PM
matty's Avatar
Probably has to do with your ACT...I know when I shift into 2nd its the most violent thing I ever feel. I love the clutch, but I wish I could keep those front wheels planted better when I race
-Matt
Old Aug 25, 2002 | 07:21 PM
Mr Cranman's Avatar
Yes I did
I did win which was nice...but the price of victory
-John
Old Aug 25, 2002 | 10:55 PM
ivelweyz
Re: Yes I did
-John
gt mustang or GRAND AM( why would you even bother with grand am's)...
Old Aug 26, 2002 | 04:05 AM
EZEMaxima's Avatar
you mentioned NAPA? c'mon, why use such a cheap part after investing so much on your car. It's mostly likely be a rebuilt CV joint on a used/reconditioned shaft. ( cleaned,painted to look like new)
May you should invest on thicker CV shafts
Old Aug 26, 2002 | 04:11 AM
$tillen$ux's Avatar
wow, didnt know that was possible! good win tho
Old Aug 26, 2002 | 09:06 AM
oCtoG3's Avatar
ur sig indicates the presence of a touch more HP than stock though???..
Old Aug 26, 2002 | 10:57 AM
Mr Cranman's Avatar
Re: Re: Yes I did
Mustang Grand am's aren't worth the gas
-John
Old Aug 26, 2002 | 11:07 AM
Mr Cranman's Avatar
Yeah I hear you...
But, where would one find a thicker CV shaft or a higher performance CV joint for his Maxima...I've looked and can't find any, obviously I'm looking in the wrong place. The only thing that I don't understand is that there are people running Superchargers and Turbochargers and I haven't heard or don't recall any of them snapping a CV shaft!!! Because I've gone through like 4 CV joints probably in the last year...this is the first one that has snapped though. But, I do agree it being rebuilt probably one of the causes. Any idea what I could do for a thicker CV shaft???.
-John
Old Aug 26, 2002 | 11:33 AM
Freedog's Avatar
Sounds to me like you've got bigger issues than the CV joints. You shouldn't be going through that many CV's in that short amount of time. There are cars on the org with major mods (I.E. turbo, superchargers, N.O.S., etc) that aren't seeing that frequency. I can't really think of any good reasons for your predicament though. Is your car drastically lowered? Drastic changes to the angles of suspension parts can cause this type of damage. Have you checked the torque values on the nuts/bolts used on the front suspension? Just suggestions. Let us know what happens, I'm curious.
Old Aug 27, 2002 | 09:30 AM
Mr Cranman's Avatar
Figured out what it probably was
Just have lowering springs, and they aren't cut. But, the CV joint problems have been because of tears in the boot and a rock or something gettting in it, and probably dropping the transmission like 4 times in a month didn't help out the driver side CV joint. But, my friend and I were talking about it. And we think we figured out why the CV Joint broke. My friend is rebuilding a Dodge Stealth so decided to put the Dodge stealth rims on the Maxima, just because I haven't had 17s on my car before. These rims are super heavy. I'm guessing maybe about twice the weight of the regular Max rims I have. Anyway...the hard shift into second along with the heavier wheel and slight larger diameter of the wheel probably caused this. So, needless to say I'm going back to the stock wheels again. Just thought I would keep you guys informed. But, the good thing about the win is with the heavier rims and bigger diameter I still beat the Mustang...because I can definitely tell that the car is slower with those heavy rims on.
-John
Old Aug 27, 2002 | 12:28 PM
timmax's Avatar
Re: Figured out what it probably was
I broke a CV joint once, but not on the Maxima. I had replaced the boots and when hammering the joint back onto the shaft, I made a small crack in the metal ring that holds the six ***** ( I think it's called a retainer) on one of the inboard joints. I ignored it and put it back together. And a few weeks later, backing down a curb with the wheel cranked it gave out, the ***** fell out and the inner shaft was just clanking around in there while the transmission was just spinning the rest of the joint. A truly terrible noise, especially when I gunned it. But I knew immediately what broke, so that was some satisfaction.
This is why I like to do my own work on my car.
Old Aug 27, 2002 | 02:35 PM
StreetMaxima01's Avatar
1/4
what do u run on the 1/4
Old Aug 27, 2002 | 02:44 PM
Mr Cranman's Avatar
Re: 1/4
I wish I knew. Don't have a 1/4 mile track close to me, but the good news is that the city is passing a bill to bring back the 1/4 mile track that got close about 2 years ago...so hopefully it will be opened up in a few months so I can got test it. And I don't have a G-tech to try it out either. But, I know G-tech's aren't that reliable but it would at least give me a ball park.
-John
Old Aug 27, 2002 | 03:18 PM
guido_sst's Avatar
Re: Yeah I hear you...
-John
Call up Raxles, they're good folks and will make you some axles that you will have one hell of a hard time breaking. http://www.raxles.com/
Old Aug 27, 2002 | 03:23 PM
Mr Cranman's Avatar
Re: Re: Yeah I hear you...
Thanks for the site I will definitely look into that. I really appreciate it.
-John
Old Aug 28, 2002 | 09:54 AM
guido_sst's Avatar
Re: Re: Re: Yeah I hear you...
No problem, glad to help out.
So... Going to give me a free VI now?
Old Aug 28, 2002 | 09:57 AM
MikeD95SE's Avatar
I used to have a 94SE and one day I was driving with my boy and while I was driving I started to hear a clunking noise so i slowed down a abit and while I was driving my damn wheel feel off I was scared as $hit.. And it was the CV Joint
Old Aug 28, 2002 | 10:04 AM
Mr Cranman's Avatar
Re: Re: Re: Re: Yeah I hear you...
LOL...unfortunately I don't have any lying around but I have some loose change you can have.
Old Aug 28, 2002 | 02:30 PM
guido_sst's Avatar
Re: Re: Re: Re: Re: Yeah I hear you...
I'll take what I can get.
aw11power
Oct 10, 2021 04:57 AM
mkaresh
Mar 12, 2018 06:48 PM
Need help
23
Oct 2, 2015 08:56 AM
dshinn
Sep 26, 2015 08:07 PM
