help...car won't start
Old Aug 26, 2002 | 05:38 AM
Supa Lao's Avatar
I turn the key and hear a click and then some tick tick tick. I can hear it try to start, but nothing. I thought it was the battery, but tried jumping it, and that didn't work. My headlights won't even turn on. When I try to start it, the dome light will even go off. Anybody have any ideas on what could be wrong? ie battery, alternator, or the starter?
Old Aug 26, 2002 | 05:52 AM
njmaxseltd's Avatar
You have a bad connection someplace. Check the battery wires on both ends. Battery and starter. Check your ground wires too.
Old Aug 26, 2002 | 05:55 AM
96SE5Spd's Avatar
Yes probalbly but if his battery is completely fried then jumping it off won't even help it.
Old Aug 26, 2002 | 07:38 AM
tmkforever's Avatar
Starter motor could be broken...that's worth checking out. This happened on my old '95 GLE. Its pretty easy to replace.
Old Aug 26, 2002 | 10:09 AM
Supa Lao's Avatar
I've been talking to some of my friends, and they think it's my starter. Do you think most automotive shops will have starters in stock?
Old Aug 26, 2002 | 10:21 AM
njmaxseltd's Avatar
Re: help...car won't start
This clue tells us you have an electrical problem. Don't replace your starter until you get proper electrical functions back.
ie. Headlights, stereo, ect...
96se5spd has a point, disconnect the neg. terninal from your battery when you jump start your car. Taking your battery out of the circuit will eliminate that from being the problem. I'd look real hard at the connections at the starter. Look for corrosion or worn & fryed wires. Follow the positive wire from the battery and check everything along it's route.
Old Aug 26, 2002 | 10:57 AM
Supa Lao's Avatar
Just got back from outside looking at the wires and all the connections. I checked my headlights and they work. Then I try cranking the car and all I hear now is clicking noises. Then I try to turn the headlights on again, and they don't work. I wait a couple minutes then they start to work fine.
Old Aug 26, 2002 | 11:00 AM
ericdwong's Avatar
Are your battery terminals corroded? Make sure that ground wire isnt chopped off, especially if you have some wierd intake.
Old Aug 26, 2002 | 11:24 AM
bill99gxe's Avatar
Evil Administrator - "The Problem"
I hate to state the obvious, but are you under the alternator recall for 97s?
http://forums.maxima.org/showthread....or+recall+date
Old Aug 26, 2002 | 01:02 PM
furbiss112's Avatar
it just happen to me.
check the ground. thats all it is. once the car is started, check for the alt. if the car does not shut off after 10-15 minutes then the the alt is fine. no need for the recall. later.
Ferhan
Old Aug 26, 2002 | 01:03 PM
nine7se's Avatar
Yea the same thing happened to my car a couple days ago and it would not jump. I had to get it towed. My problem was the starter. Since your lights wont go on it could be your battery but my car made the same noises so you might wanna get the starter checked out too!
Old Aug 26, 2002 | 01:04 PM
Sprint's Avatar
throw some pepsi on the battery terminals and then try to start it
Old Aug 26, 2002 | 01:06 PM
matty's Avatar
Re: it just happen to me.
Ferhan
There is definetly a need for the recall...the recall is for fires starting from an electrode connector inside of the alt., Not Alt failure, alt fire
-matt
Old Aug 26, 2002 | 02:35 PM
Chunger's Avatar
My other car is a Hybrid
If there isn't any corrosion at the connections (or loose connections) you battery is low/dead... caused by dead battery or failing alternator.
Old Aug 26, 2002 | 05:18 PM
Supa Lao's Avatar
I don't think it's my battery, b/c I just got a new one a few months ago. I ended up getting a new alternator. I decided to call it a nite, b/c it started to get dark and I couldn't get one stupid bolt off. Since I had my intake off and all the tubing, I checked my ground and it's fine along w/ my other wires.
Old Aug 26, 2002 | 05:32 PM
Sprint's Avatar
we never said battery.. we said terminals..
Old Aug 26, 2002 | 07:54 PM
bill99gxe's Avatar
You got a new alternator......does that mean you went somewhere and bought one or you've had one installed?
I'm not sure why you would make life harder on yourself by not getting a defective part replaced by Nissan......
Old Aug 27, 2002 | 06:14 AM
96SE5Spd's Avatar
I hate to tell you this but even if his alternator is fried his car should still turn over, something else is wrong.
Old Aug 27, 2002 | 06:17 AM
rmb's Avatar
rmb
Assuming your ground is good, it sounds exactly like a bad battery I bought a few months ago.
There was some kind of internal short within the battery.
Try removing the battery from the cables and then running off of a new one. Just get a cheap-*** sears or something to prove the theory.
-RMB
Old Aug 27, 2002 | 06:20 AM
96SE5Spd's Avatar
Re: Re: help...car won't start
-RMB
Before you go out and buy things instead of jumping it off, take your battery out and put someone elses in (if it will fit) then try to start your car. If it starts you know your problem if not well, you have a lot of work to do.
Old Aug 27, 2002 | 07:48 AM
Supa Lao's Avatar
oops sorry, I ment to say I got a new starter
Old Aug 27, 2002 | 08:15 AM
redmaxpa007's Avatar
i SeE what you did therE
does your car start now??
Old Aug 27, 2002 | 08:44 AM
Supa Lao's Avatar
not sure yet. I finally got the old starter off this morning, but when I was putting in the new one. I tightened the bolt that connects the power wire and I broke that. So I'm waiting for my sister to get off work so she can take me to the store. I hope it's my starter....it better be
Old Aug 27, 2002 | 08:47 AM
Bo Hill's Avatar
This tread is very confusing. If the starter is clicking it one of two things.
1)Either the battery is dead which you can check by turning on the lights and trying to start the car....do the light dimm out when you try and roll it over?
2) If that wasn't the problem it has to be either the solenoid or the starter itself. I went through 2 starters in 2 months so just cause you got a new one doesn't rule it out. Let us know what it was.
Old Aug 27, 2002 | 09:34 AM
Mr Cranman's Avatar
If your lights don't turn on...then your battery is dead. The cell itself is dead. If you want to be sure take the battery to Autozone, Pepboys, checker, have them test it. It is the battery or you don't have the battery hooked up to the car. Because if the battery won't hold a charge then jumping it won't do any good. I suggest you go have the battery tested before you go replacing things.
-John
Old Aug 27, 2002 | 03:23 PM
Supa Lao's Avatar
Fixed it. I put in the new starter, and the car started right up
Old Aug 27, 2002 | 03:51 PM
Old Aug 27, 2002 | 04:16 PM
CASS98SE's Avatar
This sounds exactly like a starter problem to me..
I'll bet on it
Old Aug 27, 2002 | 10:13 PM
nine7se's Avatar
Nissan is f****n w/ us cause i just got the exact same thing fixed today on my max!
97_GXE
Sep 15, 2015 06:47 AM
QueensMAX
Sep 15, 2015 04:14 AM
DarjeelingRose
Sep 15, 2015 01:20 AM
markevans999
Sep 10, 2015 04:29 PM
trungg86
Sep 4, 2015 04:58 AM
