Will these rims fit the 4th gen Maxima ?
Old Aug 26, 2002 | 06:18 PM
98SEBlackMax's Avatar
Maxima.org Insomniac
Will the 16x7 SSR Type-Cs fit the bolt/offset pattern on the 4th gen? Ive been searching on the net and the .org (using the search function for some time ) trying to find the answer. I know the Maxima bolt pattern is 5x114.3mm and the stock offset is 40mm. Even with this knowledge I still cant find the answer, I know Tirerack.com sells the 17x7.5 SSR Type-Cs but they do not sell the 16x7s . I do not want to go above or below a 16" rim and I do not want to change the overall tire diameter by alot. Also I am still looking for some good tires (Good traction in the summer and in the rain and light weight) any suggestions ?
Old Aug 26, 2002 | 07:07 PM
nismo-max500's Avatar
quoting someone on this board...
"with spacers anything can fit" i guess thats right. 5 lug of course. if they fit on tire rack in a different size they probobaly fit urs. just make shur its the maxima wheel.
Old Aug 26, 2002 | 07:19 PM
NYCe MaXiMa's Avatar
Re: quoting someone on this board...
yeah with spacers most things will fit.. but it might look rediculous.. stick out 4 inches from your fender well or something like that....
It has to be a 5 lug 114.3 mm and offset probably between 36-42 or so.. might have a little bit of rubbing possibly depending on the width of the wheel and the tire size used.. but that is a little problem..
other offsets would not be good..
email tirerack and ask them
they have a nice technical support crew, those guys know their ****. I've bought 3 sets of tires from them already.
Old Aug 26, 2002 | 08:20 PM
1MAX2NV's Avatar
It's a waste $$$ to get 16X7 wheels. By going with bigger wheels, you will not change the overall diameter of the tire by "ALOT". Why? Lower profile tires.
Old Aug 26, 2002 | 09:10 PM
If you mean having a lower profile by getting bigger rims and having a thinner (rubber band) tires, no way . The chances of ruining them are too great, One good ol' pot hole out where I live and the tires and rims are junked. I know all too well how it is too destroy tires with potholes from my first car , but those tires costed $60 a piece not like the $150 tires I have now. Also I dont care for 18" or 19" rims, it adds to much unsprung weight to the car; why dont I throw some concreate blocks in my trunk while im at it . Hey if I use bricks in my trunk some people might think its a lower spring mod . All in all I would rather have some light weight 16" rims wih some tire wrapped around them to give it a normal profile, enough said thats my $.02
Old Aug 26, 2002 | 10:41 PM
Bad97MaxSE's Avatar
Take the dust caps off the rear Hubs ..
Old Aug 27, 2002 | 07:42 PM
krbga's Avatar
I'm with 1MAXNV...
...he knows his stuff.
You have symptoms of "MOD ALLERGIES" right now.
You will exeperience "MOD FEVER" and then "MOD VIRUS"
enjoy the ride
Lakersallday24
Nov 7, 2024 07:31 PM
CRizz
41
Jun 7, 2021 05:42 AM
morteljc
Oct 19, 2015 10:47 AM
Finkle
Sep 27, 2015 09:53 PM
