tranny becoming less responsive
Old Sep 3, 2002 | 12:52 PM
Roman-dude's Avatar
Hey, it seems that my tranny is becoming less responsive and takes longer to shift (obviously auto). Is that something that will be cured by a regular tranny oil change or is there something else to it?
Old Sep 3, 2002 | 12:59 PM
Iqb316's Avatar
How long has it been since the last time you flushed your tranny fluid? If it's been quite a while, try doing that first and see if it gets better.
How many miles on your car?
Old Sep 3, 2002 | 01:03 PM
Roman-dude's Avatar
i haven't done that yet, but the last time i changed oil (a month ago) they said it was fine. I've had it for 1.5 years and only put some 10k on it since then. the total milage is 84K
thanks
Old Sep 3, 2002 | 01:21 PM
iwannabmw's Avatar
thanks
Normally the tranny fluid is changed at the 60K service, but this is the most often ignored item. I'd bet it wasn't changed, meaning your overdue.
Old Sep 3, 2002 | 04:52 PM
HondaKiller718's Avatar
I changed my tranny oil and the shifts felt smoother and more responsive. Plus it feels good to change dirty fluid
Old Sep 3, 2002 | 08:01 PM
jkotel's Avatar
my max has 84k on it as well and I just got the tranny flushed.... you do feel the difference...
Old Sep 3, 2002 | 08:07 PM
95seMax's Avatar
do u guys recomend flushing the tranny oil yourself or getting it done at the dealer
Old Sep 3, 2002 | 08:56 PM
96shogunmax's Avatar
tranny flush
Dealer just done mine today. cost me $49.00. feels much more responsive. shifts better. 99,000 miles......first one ever.
Old Sep 4, 2002 | 07:17 AM
iwannabmw's Avatar
Re: tranny flush
The dealer probably didn't flush it then, just a drain and fill.
Old Sep 4, 2002 | 10:50 AM
Re: Re: tranny flush
no i saw him hooking it up to a machine.....
Old Sep 4, 2002 | 11:43 AM
iwannabmw's Avatar
Re: Re: Re: tranny flush
Wow, that's a phenomenal deal then.
Old Sep 4, 2002 | 11:47 AM
Re: Re: Re: Re: tranny flush
thats what i said , but i didnt argue....
Old Sep 4, 2002 | 12:57 PM
Roman-dude's Avatar
what's the usual price for the flush?
thanks
Old Sep 4, 2002 | 01:14 PM
Re: Re: Re: Re: Re: tranny flush
thanks
around 90 i think
Old Sep 4, 2002 | 02:11 PM
iwannabmw's Avatar
thanks
I've seen ranges from $80-$150. Pretty steep considering you can DIY pretty quickly.
Old Sep 4, 2002 | 02:57 PM
XXXL Cracker's Avatar
Re: Re: Re: Re: Re: Re: tranny flush
How do you flush it completely yourself?
Dave in York
Old Sep 4, 2002 | 07:17 PM
iwannabmw's Avatar
Re: Re: Re: Re: Re: Re: Re: tranny flush
Dave in York
This was originally posted by Jime:
Draining the pan will usually yield 4 litres, the whole system is 10 litres. If you want to drain and flush the whole thing I posted this earlier on another thread when I installed a transmission cooler. Drain the pan first, replace plug and refill with 4 litres or the amount you drained out. Do not start the engine. You need to disconnect the hose from the transmission to the radiator.
I used a 1 gallon clear windshield washer jug, put the end of the transmission hose in the jug and get someone to start the car and then yell when you want them to stop, it comes out fairly quickly but not enough to force the fluid out the jug top, but make sure you hold on to the hose and the bottle to keep it steady. It takes about 15 or 20 seconds to get half a jug which is what I did and then refilled and did another half a jug till it came clear. It took 10 litres for me. I have read that some people did it in 1 gallon increments and others 1/2 so I did the half.
I did a cooler install at the same time so I had a long enough hose on the output from the transmission to easily run to the jug but the stock hose is short so might be advisable to put a longer one on or attach an extension to it.
Also just put back in the same amount you take out and then run it a while after you are all finished. I found that the stick showed low at first but came back after a short drive so I was glad I didn't add the extra litre I had purchased.
Old Sep 9, 2002 | 07:01 PM
gkush's Avatar
My trans with 76,000 miles had a shudder on shifting. I had the fluid changed back at 30,000 miles and thought it was just plain dying at this point. Took someone's advice and had the full flush today. Cured the problem. Paid $119.
fx4five
Oct 18, 2015 06:57 PM
fx4five
Oct 1, 2015 04:58 AM
Sep 27, 2015 08:37 AM
zmcneely13
Sep 26, 2015 02:26 PM
