APEX WS Exhaust install question/problems! HELP
Old Sep 6, 2002 | 11:08 PM
dtholmanmax's Avatar
put on my Apexi WS cat-back tonight and was confused. right behind the cat is the o2 sensor plugged into a piece of pipe. clearly the apexi doesn't have a place for the sensor and we also couldln't get the damn sensor out of the piece of pipe
so we cut the wires to the sensor and said F-it. Now what SHOULD i have done since there is no place for the sensor anyway? Plus, now i'm getting a service engine light b/c of the lack of the sensor. Thoughts/opinions. I'm a little annoyed that I just paid for this damn thing and it doesn't fit EXACTLY like I want it to/how it should.
Old Sep 7, 2002 | 12:26 AM
sbslacker's Avatar
Jeez, dude...you CUT the wires to the rear O2 sensor and said F-it? Ummm....yeah, doing that WILL set off a code. My advice? Reconnect the O2 sensor, drill a bung hole in the b-pipe for it, connect it, and all you probs will be solved. Good luck.
Old Sep 7, 2002 | 07:28 AM
Well, the only real reason I cut it was b/c we couldn't get the damn thing out of the old pipe and we already had it all apart. Plus, there was no way I was/am going to be doing any drilling on my own. So for the moment, I just cut it. The part that frustrated me was that I didn't realize this was part of the deal/there was not a place to put it in from apex originally. I just wish it would have said so in the directions.
Can i have the sensor hole drilled at a regular muffler shop?
Old Sep 7, 2002 | 07:54 AM
Vyrus's Avatar
The Apexi catback was designed for '95-'96 Maximas which have the rear O2 sensors in their cats. You will have to drill in the stock O2 sensor because you have a '98. Unfortunatley because you cut it you will definitely set off the CEL, and caused a little more work for yourself because you will have to reattach it.
-Cyrus
Old Sep 7, 2002 | 06:13 PM
maximusx20's Avatar
can u do this drilling thing if u get a greddy from 96........andput it on a 98?
Old Sep 7, 2002 | 07:49 PM
Vyrus's Avatar
Yes, that's exacty his problem except with a catback from a different company.
-Cyrus
Old Sep 7, 2002 | 09:29 PM
maximusx20's Avatar
cool cause i just bought a greddy exhaust used froma guy with a 96 and did not figure a 96 until after i pay paled him.....ohh well i guess i will have to tell the shop guy to drill for a o2 sensor...
Old Sep 8, 2002 | 12:32 AM
jules's Avatar
you will enjoy the sound of the apex WS once it is installed. It is very quiet at idle but really comes to life around 3k-5k RPM. I really cant hear my exhaust anymore after about 4k RPM because of my intake, but i recall the apex really growling at about 3k and taking off from there when I didnt have my intake.
Oh yea, you wont feel anything performance wise from your butt-dyno.
Jules
Old Sep 8, 2002 | 12:58 AM
ThurzNite's Avatar
apexi ws vs greddy sp...tough choice! I'll take 1 of each and do a true dual exhast from the head. Heehee.
As for the O2 sensor, I used a crescent wrench and a lotta force. Drilling the new hole might be tough cuz the pipe's round. I'd start with a pilot hole (small diameter bit) and work your way up. If you can't get the small bit to go, try making an intentation on the pipe with a nail and hammer. That should keep the bit centered while you get started.
Good luck and let us know how it goes (cuz I got a 97 max and dunno if i'm going custom or prefab catback)
Jae
Old Sep 8, 2002 | 03:32 AM
TurDz's Avatar
-Cyrus
dude man I have commend you for that answer. I was stumped when I first read the thread but your answer was one of those, "ohh yeah!!!" kinds. haha. i know, its late.
Old Sep 8, 2002 | 06:45 AM
NickStam's Avatar
youshoulda done your research on the org first
Old Sep 8, 2002 | 07:30 AM
Vyrus's Avatar
Old Sep 8, 2002 | 11:50 AM
Vesaijan's Avatar
I've gotta question: I noticed that there is a metal shield on the stock b-pipe. What is that for?
When I install my catback should I keep that and put it on the new exhaust, or just pitch it?
RL
Old Sep 8, 2002 | 02:29 PM
EZEMaxima's Avatar
I had to do the same thing to my Apexi exhaust. I had to drill a hole and then weld in a nut the size of a 18M with a 1.5m pitch. And got some high temp paint and sprayed it on the newly welded nut. It's been two weeks now and so far so good, no CEL for me.
Old Sep 8, 2002 | 04:31 PM
RedMax95's Avatar
so ya pretty much what i said
Old Sep 8, 2002 | 06:28 PM
pmg's Avatar
pmg
I had an exhaust shop put a new hole in when my early warpspeed y-pipe holw was way off. The welded a new threaded fitting on - that's probably better than just drilling a whole.
Old Sep 8, 2002 | 09:16 PM
About how much did that cost? I'm also going to have to get one of the hangers on the rear heated up b/c it's banging against the spare tire thing in the back.
thanks guys.
Old Sep 9, 2002 | 12:13 PM
maximusx20's Avatar
yes how much for installation for those of u who paid and.....is yes that it will work the same way on a 96 greddy to put on my 98 and how does the muffler stick out i heard it more flush then it would be on a 96..
Old Sep 9, 2002 | 01:12 PM
hokiemax's Avatar
I have a question. The bpipes of the Apexi WS, are they connected by flanges or are they welded together? Or is it just a 1 piece design? I'm asking this because some guys have leaks with courtesy or stillen bpipes, where the flanges meet.
Old Sep 5, 2003 | 04:08 PM
Taken2DaMax's Avatar
Another question: what did you guys use to extend the exhaust on a 1997-1999 max?
Old Sep 5, 2003 | 06:36 PM
ivelweyz
thanks guys.
$10
The APEX'i b-pipe is a one piece design...
MaxLife17
Jun 27, 2019 01:37 PM
BkGreen97
Apr 2, 2016 05:47 AM
TheMafia
Sep 4, 2015 08:26 AM
Justin Kroll
Sep 2, 2015 11:06 AM
A32goldylocks
Sep 2, 2015 06:39 AM
