O/D LIGHT......
Old Dec 18, 2000 | 09:34 AM
sbmax95's Avatar
The other day I noticed when I started my car, my O/D light was flashing. It usually just comes on for a second and goes of with the other idiot lights. Has this happed to anyone else? Does it mean anything?
Old Dec 18, 2000 | 09:42 AM
dch95's Avatar
Overdrive
As far as I can tell,the wiring diagram for the light shows that it goes to the Automatic Transmission control unit located underneath the ashtray. Do any stereo or other type of work in this area? Does the transmission go into overdrive and/or shift normally?
Old Dec 18, 2000 | 09:50 AM
sbmax95's Avatar
No. their is nothing going thier, and it does go into overdrive and also shifts correctly. It only did it that one time. Hasn't done it since.
Old Dec 18, 2000 | 09:51 AM
GIMAX's Avatar
O/D light flashing usually means there is
something wrong with the transmission.
similar to the check engine light. I believe
the O/D light also flashes out codes, to tell
you what's wrong with trans. I would get it
checked out.
Old Dec 18, 2000 | 10:59 AM
Matrix's Avatar
hmmm
If it only came on that one time, I think the cars computer detected a fault with the automatic transmission when it started up. But perhaps it was not actually a problem and now your car doesn't see it anymore?
If it happens again, go get it checked out
otherwise ask them to take a look at your next oil change or whatever.
Old Dec 18, 2000 | 11:10 AM
dch95's Avatar
O/D Light
checked out.
Turns out you are correct about this. In the FSM starting on page AT-46 it gives directions on how to do this. I would write it up but 4 pages and if I had a Scanner I could do this but alas I do not. Sorry
bryants95max
Oct 2, 2015 12:52 PM
dcardello
Sep 3, 2015 11:44 PM
CalsonicSE
Aug 23, 2001 10:59 AM
Daniel B. Martin
Aug 12, 2001 01:14 PM
Mike S.
Oct 24, 2000 07:43 AM
