injen vs. frankencar
Old Sep 14, 2002 | 01:30 PM
NisMouNtaIndEw's Avatar
anyone in here had both frankencar and injen CAI befor? i searched and found differant opinions, millions needless to say, but i havent really talked to anyone whose had them both and told me their opinion of it...so far ive come to the conclusion that the franken car puts out better sound but power wise i should go with the CAI? thanks everyone
Old Sep 14, 2002 | 02:09 PM
Street Reeper's Avatar
Handsome
It's confusing
CAI draws in cool air but it is said that the tube becomes restricting at high speeds.
The argument that the air in the tube creates a ram effect is just not true without a carb, if the tube is air tight, the air moving through the tube will be at the same speed that it moves through the filter.
A pop charger has no tube but gets air from in the engine bay.
A frankencar has a tube and gets air from inside the engine bay, it seems that it has both disadvantages, most of the gains are probably from the upgraded filter.
I would go with the CAI
Old Sep 15, 2002 | 11:30 AM
HLMAX's Avatar
It all have to do with were in the RPM range you want power. Longer pipe at the same diameter will resonate at lower RPM, creating pressure waves that actually pushes air into engine. Low RPM power, Injen. Mid RPM power, Frankencar. High RPM power, pop charger.
Old Sep 15, 2002 | 02:18 PM
ivelweyz
So FRANKENCAR is better, both mid and high RPM ranges are covered...
Old Sep 15, 2002 | 03:14 PM
HLMAX's Avatar
If you look at the Frankencar dyno charts, the increase in hp is still very high in the RPM range. But what can you do? If you look under you hood, there is no more room to increase the length of the intake pipe. Unless you put bends in it like Injen or PR.
Ahhh, maybe if I move the battery to the trunk and increase that mid pipe a few more inches.
Old Sep 15, 2002 | 03:36 PM
Toolrocks's Avatar
That sounds like the Fast Lane Performance intake (FLP). Btw, I currently have the Stillen pop charger and the $15 upper intake piece. http://drwebdesign.com/mymaxima/upperintake.html This combination has netted me my best 1/4 miles. I'm stick. I think most autos get the CAI.
Old Sep 15, 2002 | 04:13 PM
BBaker025's Avatar
Dont want to get off topic, But is there much of a difference between Ingen CAI and Place Racing CAI?
Old Sep 15, 2002 | 08:36 PM
WDragonM's Avatar
Question for people with the injen intake
For people with the injen intake, can it be turned into a HAI during winter when there's a lot of rain or whatever? The reason why I ask is because since it requires no drilling, I was wondering about the angling for the filter. Thanks.
Old Sep 15, 2002 | 09:40 PM
are the injens carb legal? what puts out better sound?
Old Sep 15, 2002 | 10:50 PM
Tifosi's Avatar
Re: Question for people with the injen intake
Most likely not! Look at the first page of my homepage. I have a pic you can see where the filter position is. And I really don't see how you can make it an HAI, not enough room.
Tifosi
Old Sep 21, 2002 | 10:29 PM
NYCe MaXiMa's Avatar
good question
Where can i find more info on the Injen CAI, like what it is, whats so good about it opposed to other CAIs.. installation etc...
Mahmuth
Sep 25, 2015 10:08 AM
Dasmith
Aug 25, 2015 10:15 PM
Y2KevSE
72
Aug 4, 2008 08:21 PM
ajaffee
Mar 15, 2001 11:20 AM
