ATTN: Daniel B. Martin
Old Dec 18, 2000 | 09:14 PM
DaEnigma's Avatar
I was hoping you could help me figure out what my problem is. My car seems to be pulling to the left after I had the Koni/Eibachs installed but the weird part is I had is aligned twice and it still does it…
The pull is not really bad, but on the freeway if I let go within ~6 seconds it will be all the way in the next lane to the left...
Here are the specs from the alignment:
Driver Front:
Caster 2.6
Camber -.1
Toe 0.00
Passenger Front
Caster 2.7
Camber -.4
Toe -0.05
Driver Rear:
Camber -.8
Toe -.10
Passenger Rear
Camber -1.2
Toe .30
Thrust Angle -0.2
Any help would be great!
I need to get this fixed ASAP...
One more thing can you post the specs on an alignment for a 1999 Max?
Old Dec 19, 2000 | 07:23 AM
DaEnigma's Avatar
Is the Dr. in yet?
Old Dec 19, 2000 | 07:24 AM
Daniel B. Martin's Avatar
Originally posted by DaEnigma
... ... can you post the specs on an alignment for a 1999 Max?
This information is from the '99 Maxima factory service manual.
FRONT WHEEL ALIGNMENT
Camber, in degrees.
-1.00 Minimum
-0.25 Nominal
+0.50 Maximum
+0.75 Maximum left and right difference
Caster, in degrees
+2.00 Minimum
+2.75 Nominal
+3.50 Maximum
Kingpin inclination, in degrees
+13.50 Minimum
+14.25 Nominal
+15.00 Maximum
Total toe-in distance, in millimeters
+1 Minimum
+2 Nominal
+3 Maximum
Total toe-in angle (left plus right), in degrees
+0.09 Minimum
+0.18 Nominal
+0.27 Maximum
REAR WHEEL ALIGNMENT
Camber, in degrees
-1.75 Minimum
-1.00 Nominal
-0.25 Maximum
-3 Minimum
+1 Nominal
+5 Maximum
-0.27 Minimum
+0.09 Nominal
+0.43 Maximum
[Edited by Daniel B. Martin on 12-19-2000 at 09:41 AM]
Old Dec 19, 2000 | 07:35 AM
DaEnigma's Avatar
I'm no mechanic..
So what does that all mean in reguard to my listed specs?
I just want to know what to tell the next place I take it...
Thank you again
One more thing the rear is SOL correct?
[Edited by DaEnigma on 12-19-2000 at 09:38 AM]
Old Dec 19, 2000 | 09:09 AM
Re: I'm no mechanic..
I don't have alignment equipment, so I rely on a shop for that kind of work. Ask around town for recommendations. Lots of places will do an alignment, but relatively few make it their specialty. You need a specialist for this job.
The trouble with some shops (especially the guys who advertise a $39.95 "special") is that if a wheel is anywhere within the "factory spec" range they won't adjust it at all. Their attitude is "Duh, it meets the spec, that's good enough." You have to find the skilled technician who will take the time to adjust your car until each of the four wheels is at the Nominal specification, or as close as humanly possible. Be prepared to pay extra for this because it takes extra time.
Old Dec 19, 2000 | 09:16 AM
... My car seems to be pulling to the left ...
The pull is not really bad ...
Let's not forget the basics. Verify that all four tires are inflated equally. If the pull persists, exchange the front wheels. If the pull changes, the problem is a bad wheel or a bad tire. Steering pull is not always the fault of the alignment man.
Old Dec 19, 2000 | 09:18 AM
MaxRod33's Avatar
Re: Re: I'm no mechanic..
Daniel, are those alignment specs the same as for a 96 Maxima? Thanks.
Old Dec 19, 2000 | 09:58 AM
Re: Re: Re: I'm no mechanic..
They were carefully copied from the '99 Maxima factory shop manual. I don't have a manual for the '96, but imagine it is the same. Chilton and Haynes don't provide alignment specs.
CKNY
May 2, 2001 08:58 AM
CKNY
Apr 29, 2001 07:40 PM
B.C.
Apr 18, 2001 11:20 AM
ericdwong
Apr 10, 2001 08:38 AM
tonymich
Feb 8, 2001 09:22 PM
