HELP - Frankencar installatoin.. Car won't start now
Hey I tried to install the frankencar intake, when we were installing it the maf came out of the maf control (box) we put it right back in, but my friend thinks this is what messed it up. Now when we start the car the ignition goes but it won't turn over and it won't start. There's no way it can drive so i can't bring it to a dealership to have them look at it? what should i do? do i need a new maf sensor?
bob
bob
Re: HELP - Frankencar installatoin.. Car won't start now
bob
bob
When your MAF fails, you would still be able to start the car but it won't go over 2000RPM. Make sure you didn't disconnect any harnesses from the sensors around the intake area.
Deezo, when you say don't disconnect any harnesses near the intake area.. when we were putting in the cold air, we unbolted these connections, they had a little bracket on the intake, but we unbolted it and they are just sitting there free, this sounds bad but we didnt see how they could connect to that bracket because it seems that all their connectoins are right there and dont plug into it, making screwing the bolt back into the bracket seem pointless in our problem. I just went out there before this post and the grey plug to that box is the maf right? it's as tight as its gonna be, car tries to start keeps trying as long as i have the key in but it just wont turn over, do you think if i connect that group of wires to that bracket again it would have anything to do with it? i just dont seem how it is possible.
thanks
bob
thanks
bob
What your describing sounds like the ignition wire to the starter relay is not connected anymore. You have power, but nothing is telling the relay to close for the starter to turn.
Check around your install again very carefully, there's a wire off someplace.
thank you very much, the problem isn't solved yet, but will be soon... hopefully, i think your right saying the wire is off from the ignition to the relay because the car is trying to start.. it doesn't sound any less powerful, it's just trying to start up normal.. and it doesn't "catch" it just keep on trying to start before the actual catch takes place. Does anyone know where this wire is from the ignition to the relay? thanks a loT!
did you make sure you have all the vaccum hoses and everything hooked back up, cause it wont run if they arent. one of mine popped off while i was driving and i lost all power in the middle of the road, it was horrible. happened same day i installed my hybrid.
I bet your vaccum hose is leaking / not secured, its the top hose there that should be under the fstb if you have one.
u can actually drive it now, put yr right foot on gas, then put left foot on brakes, then put it in D with a little bit of gas, then let th ebrakes go & the car will move, BUT as soon as you let the gas go the car will stall.
ive tightened the hoses as tight as they can go.. i am absolutley clueless as to what is wrong.i dont really wanna get it towed to nissan because they'll charge an arm and a leg, anybody else have any other ideas on what i should do? thanks
bob
bob
on top of this, ive tried to get to the ecu and the damn selector screw is so freggin small, i cant get a screwdriver small enough to freggin turn the screw! and ive been using a flathead eyeglasses screwdriver! !$#@$#$#@$@! sorry, just venting
maybe so.. but it looks like i'll be towing it to nissan tomorow b/c i can't figure anything out. damn nissan dealerships!
blah now im gettin scared cuz i just ordered my frankencar... i'm pretty experienced w/ the stuff but ahhhh i can't afford any problems, i barely squeezed for the 50 bucks lol
I think I know what your problem is, because Ive encountered almost the same problem. If you dont have a bracket to hold up the cone part of the intake, The whole Mid Pipe will fall off. Due to that Little rubber piece that came with the mid pipe that does frfom the pipe to the Throttle Body. When You put that on, as tight as you can, the intake with the mid pipe is so heavy, it just falls off. Do what I did. Go back to that little stock black filter box you took out of the car, and take off that rubber flex section that was on that box that connected to the throttle body. Put it on the mid pipe in place of that rubber hose. Then connect to the Thottle Body. What that does is if you dont have a braket fo the intake, it will let it slop of the trottle body without Falling off because of the flexable part on the rubber.
I hope this helps, It helped me
Thanks for all the help guys, but my car is being towed to nissan today so i took out the intake ( i will be selling it too ) and put the stock back in. I realized that i should first get money to get wheels/tires before i do any performance mods, seeing as im still sitting on hubcaps.
Sorry I took so long, but the dealer said my clutch sensor went bad, took abour $200 out the pocket to fix, I ended up selling my intake and putting the money towards a body kit, which I now have on my car. I have stillen/ionics. I also ordered some 18" wheels for the spring, I decided to go with show for now until I become smarter about the maxia and moddin it. F'ing up the frankencar installation really put me down mentally, lol. I'll get over it when my car is looking bling-bling this spring.
Bob
Bob
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
MAXSE5SPD
Aug 23, 2015 12:06 PM
BobMax
Aug 15, 2015 12:35 PM
