Problem With Shifting ..
Old Sep 23, 2002 | 08:14 PM
DFord97's Avatar
Today on my way back from school .. I had some problems shifting. The car is driveable, but there is a noticable pause between when i shift, and when the gear engages. When i accelerate into the next gear, i feel nothing for a second or two and the tach goes up, before you feel it engage. Could it be the clutch? Only 30,500 miles on the car, bought it at 28k.
Thanks.
Old Sep 23, 2002 | 08:38 PM
meccanoble's Avatar
Sports Button FTW
Re: Problem With Shifting ..
Thanks.
i think your clutch is slipping.
When i first had conversion done, mine did the same thing. I had to reach high rpm's just to get the power of if i were at 2 or 3k....
then i got my pedal adjusted and it worked perfectly. Being that you haven't had this problem before, maybe u abused your clutch too much?
is this your first 5 speed? do you race hard all the time?
Old Sep 23, 2002 | 09:18 PM
sryth's Avatar
Re: Re: Problem With Shifting ..
I would definitely agree that it's clutch slippage. When you're driving at ~3.5 krpm, take your foot off of the gas, the floor it. Watch your tachometer and speedometer. If the tachometer climbs, but the speedometer doesn't, your clutch is slipping.
That's pretty low mileage for a worn clutch, unless you always speed shift. Maybe you just need it adjusted?
I had this problem when I first got my PRCAI. The clutch was fine beforehand, but I guess the bump in HP made it easier to slip it
This'll give you a good excuse for getting an ACT clutch
-Sryth...
__________________________________________________ ____________________________
'98 SE 5spd, Pebble Beige, PRCAI, Stillen Y, Stillen FSTB, ACT clutch.
Pacesetter STS to be installed this week!
Old Sep 23, 2002 | 10:04 PM
DFord97's Avatar
this is my first 5 speed .. but i had to not drive the car for about a month or so and it was fine, today I drive it for the first time and this problem arises. I drive it hard sometimes, but I've only had the car for a couple thousand miles and I don't think i drive it THAT hard. It's due for it's 30k maintenence anyways so I guess I'll get it checked out.
Old Sep 23, 2002 | 11:14 PM
sryth's Avatar
I'm assuming that it's still under warrantee. I'd take it back and complain about it. They might do something. They should at least look at it for free if it's under warrantee.
-Sryth...
Old Sep 24, 2002 | 12:12 PM
DFord97's Avatar
so i went to drive it to school today ....
problem was still there, only this time, about 10 minutes into my ride, it stops functioning completely. every time i tried to accelerate it just redlined and did nothing ... then came a nasty smell and you could feel heat coming from the clutch if you put your foot there. this cant be good. i was in the far left lane and managed to get the hazards on and get all the way right and roll onto a side street where my car is parked right now. i will get it into a shop but am i definitely going to need a new clutch?
Old Sep 24, 2002 | 04:31 PM
sryth's Avatar
Either you'll need a new clutch, or it's just SERIOUSLY out of adjustment. I'd bet on the first one, though.
If you do end up needing a clutch, what kind are you going to get?
-Sryth...
Mar 12, 2020 12:06 AM
ajahearn
Sep 19, 2015 03:03 PM
2kmaximel
Sep 16, 2015 03:19 PM
