Valve/cam specs
Valve/cam specs
I was wondering if anyone has the cam duration(inatake and exhaust), and the valve diameters, intake and exhaust. I tried searching, and all I could find was a thread with valve stem dia. and spring I.D's. Although now that I think of it, it may be printed on the underside of the hood. But I am nowhere near my car right now, so I cannot check.
Re: Valve/cam specs
VALVES & VALVE SPRINGS
Application Specification
Intake Valves
Face Angle :. 45deg 15’-45deg 45’
Head Diameter: 1.417-1.429" (36.00-36.30 mm)
Minimum Margin: .020" (.50 mm)
Minimum Refinish Length: 3.831" (97.32 mm)
Stem Diameter: .2348-.2354" (5.965-5.980 mm)
Valve Tip Maximum Refinish: .008" (.20 mm)
Exhaust Valves
Head Diameter: 1.228-1.240" (31.20-31.50 mm)
Minimum Refinish Length: 3.734" (94.85 mm)
Stem Diameter: .2341-.2346" (5.945-5.960 mm)
Valve Springs
Free Length: 1.847" (46.93 mm)
Out-Of-Square: .079" (2.00 mm)
Pressure
Standard: 102.1 Lbs. @ 1.08 In. (46.3 kg @ 27.55 mm)
Service Limit: 96.2 Lbs. @ 1.08 In. (43.7 kg @ 27.55 mm)
That's all I found with a quick search of the FSM. I hope it helps. What's this for, anyway?
Yeah, it's a little project I'm working on. Do you happen to have lift/duration of the cams?
Originally posted by SteVTEC
Yeah I'd like to see this too, just for comparison purposes on some other engines I have specs on.
I don't know how accurate that is, so take it for what it's worth.
I couldn't find anything in the overhaul manual from Nissan.
James92SE
142
01-02-2024 09:23 AM
jmlee44
10-02-2022 02:13 PM
