help! 02 01 and 0608
Old Oct 14, 2002 | 08:47 AM
Jamsan's Avatar
i was coming out of school, and my car just like bucked, and the check engine light came light on.....the car would hesitate when it would idle with my foot on the brake, and it would buck under moderate acelleration.....i thought it was something loose with my y pipe....but i guess not, i dunno what the problem could be?? help!
Old Oct 14, 2002 | 09:27 AM
blakkrob's Avatar
GOOD LUCK
I tried to get help two days straight and didn't get a response. I am having a similar problem but the only code I have is 0201. My idle is normal my car only bucks in the morning when the engine is cold . I t happens while I am driving @ aorung 1500RPM's.
0201=Ignition signal primary circuit fault
0608=Cylinder #1 misfire detected
from what I have read this could mean a bad ignition coil
Go to the search function and you'll find ways to test your ignotion coils
Old Oct 14, 2002 | 09:56 AM
Sprint's Avatar
Bad Coil Pack Check
http://forums.maxima.org/search.php?...der=descending
DTC 0201
DTC 0201 and DTC 0608
http://forums.maxima.org/showthread....light=DTC+0608
Old Oct 14, 2002 | 10:12 AM
bill99gxe's Avatar
Evil Administrator - "The Problem"
So, you're saying that if search was used with nothing more than the 4 digit code(s) then immediate results would have been available with a full breakdown of the issue(s) and possible solutions rather than expecting to be waited upon like a King?
Old Oct 14, 2002 | 10:15 AM
Sprint's Avatar
nah what i am saying is.. all i had to do was punch in 4 digit codes in that there search function and like wham.. kazzam .. boom.. the **** just appeared.. it was amazing.. it had all the **** i was looking fer.. and even other **** i could do to.. damn.. if i didn't do this.. i would have to wait around like i was the king or some ****..
thas all i am saying
Old Oct 14, 2002 | 11:32 AM
Sprint's Avatar
ok had a couple of bad links.. due to cookie error.. but anyway..
DTC 0201
http://forums.maxima.org/showthread....t=DTC+and+0201
Check Bad Coil Pack
http://forums.maxima.org/showthread....pack+and+check
Old Oct 14, 2002 | 01:36 PM
Jamsan's Avatar
ok my friend has a few extra coil packs lying around, so we'll swap one out and see if that does it.....also, i just had my y pipe installed last week, it couldnt have anything to do with this at all, could it?
Old Oct 14, 2002 | 04:37 PM
Jamsan's Avatar
PROBLEM SOLVED!!!
Yes. It was a bad coil pack indeed. A friend came over, and he had a couple extra coil packs. We unplugged the connector from cylinder 1 with the car on, and the car was the same, unplugged it from cylinder 2, and it got worse, so we plugged that back in, swapped out the cylinder 1 coil pack, started it up, and it ran like a champ..
raced my friend have (97 se auto, cai,ypipe, b pipe), and showed him who the man was
Old Oct 14, 2002 | 05:30 PM
Sprint's Avatar
Re: PROBLEM SOLVED!!!
cool.. glad to hear thing worked out for you..
Old Oct 14, 2002 | 05:36 PM
Jamsan's Avatar
ya thx for all the help also..
Old Oct 14, 2002 | 06:18 PM
bill99gxe's Avatar
nupemaxima
Jun 8, 2008 06:05 PM
darklegend06
Mar 13, 2006 10:32 AM
Endlesswave
Nov 24, 2005 08:31 AM
Dev
Jun 13, 2003 04:01 PM
