"Pigeons" sound coming from right wheel when turning...
Old Oct 15, 2002 | 08:33 AM
Speebs's Avatar
I aim to misbehave.
That's right... when I turn the wheels, it sounds like there are pigeons in the front passenger wheel. Could this be the CV joint, or is there another possibility? (and no, it is not really pigeons)
Thanks!
Doug
Old Oct 15, 2002 | 09:30 AM
Bags's Avatar
VG Ridah's Biatch Hoe
ok.. does it change with speed?
sounds like a wheel bearing more than a CV
Old Oct 15, 2002 | 09:32 AM
Speebs's Avatar
I aim to misbehave.
It does seem to go away at higher speeds, then again I'm not turning the wheel as much when I'm going faster than 5mph. I can hear it sometimes when I'm turning corners, though.
Old Oct 15, 2002 | 10:39 AM
njmaxseltd's Avatar
Can somebody tell me what a Piegon sounds like?
Old Oct 15, 2002 | 10:47 AM
mzmtg's Avatar
Minister of Silly Walks
[pigeon voice]
Help! I'm stuck in a wheel! Help!
[/pigeon voice]
Old Oct 15, 2002 | 11:44 AM
njmaxseltd's Avatar
Originally posted by mzmtg
[pigeon voice]
[/pigeon voice]
Old Oct 15, 2002 | 01:08 PM
max1ma97se's Avatar
tire might be rubbin
Old Oct 15, 2002 | 01:59 PM
thebigsadler's Avatar
have you checked to see if there are any pigeons lodged behind the wheel?
SuDZ's Avatar
Check your power steering fluid.
SuDZ
Old Oct 15, 2002 | 02:03 PM
Speebs's Avatar
I aim to misbehave.
SuDZ
Thanks, sudz... the fluid seems fine and I topped it off with my last oil change a month and a half ago.
Old Oct 15, 2002 | 05:14 PM
VeeQueue's Avatar
Maxima.org Sponsor and Donating Maxima.org Member
Re: "Pigeons" sound coming from right wheel when turning...
Thanks!
Doug
Sounds like your power steering belt is slipping.
Old Oct 15, 2002 | 05:19 PM
Speebs's Avatar
I aim to misbehave.
Re: Re: "Pigeons" sound coming from right wheel when turning...
BRILLIANT. That sounds very possible. I kbnow it's not the tire rubbing (stock suspension setup) and there ARE NO PIGEONS IN MY WHEEL. I think that would make more of a repetitive "thunk" sound anyway.
How do I go about checking the belt? Is it easy to access? Easy/expensive to replace?
Thanks again,
Doug
Old Oct 15, 2002 | 05:38 PM
VeeQueue's Avatar
Re: Re: Re: "Pigeons" sound coming from right wheel when turning...
Thanks again,
Doug
The PS pump is close to the oilfilter (near the bottom of the engine). After you locate the power steering pump turn on the engine and observe the pulley first to see if its wobbling (to rule out bad a bad pulley). If the pulley doesn't shake then take care of the belt. You'll need to either adjust the tension of the belt or replace it; I'd replace it. You can access the adjustment bolts from the bottom.
It's something a DIYer can do; at the very least get a Haynes manual. There are step-by-step instructions with clear photos floating around in the net; I'm sure you can find it with google or the search function in here. I would go ahead and replace both drivebelts at this time.
If you want your mechanic to replace it the prices are generally $10 a belt and the mechanic will probably charge you 1hr labor.
Old Oct 15, 2002 | 05:51 PM
Speebs's Avatar
I aim to misbehave.
Re: Re: Re: Re: "Pigeons" sound coming from right wheel when turning...
Cool. Thank you so much for your help- I am relatively adept mechanically and have been underneath the car numerous times, so I will give this a shot.
Thanks again!
Old Oct 15, 2002 | 07:10 PM
JoesMAX's Avatar
Old Oct 15, 2002 | 08:46 PM
Bad97MaxSE's Avatar
Is there a nest back there ?
homeyclaus
Sep 3, 2015 06:15 PM
seesole
Aug 26, 2015 11:22 AM
BobMax
Aug 15, 2015 12:35 PM
follyburr
Aug 7, 2015 09:50 PM
Jcof88
Aug 3, 2015 10:43 PM
