Need advice on heater fan problem
Old Dec 23, 2000 | 12:04 PM
speedy
I just replaced the thermostat on my 95 gxe and it fixed my heat problem but the 1-3 fan speed doesn't work. $ works fine but 1-3 doesn't. If anyone has any advice it would be greatly appreciated
Old Dec 23, 2000 | 12:14 PM
Daniel B. Martin's Avatar
There is a resistor assembly mounted on the air duct close to the blower
motor. That part has failed. It is used to control fan speeds 1, 2, and
3. Speed 4 is the maximum blower motor speed, so no resistors are
involved. Replacing the resistor assembly is something the home mechanic
can do. The only tool needed is a Phillips head screwdriver.
The Haynes manual has a good photo of this part on page 3-8.
Old Dec 23, 2000 | 01:32 PM
Eric L.'s Avatar
Dan Martin is correct in that it's the blower motor resistor. I've found that most Japanese cars have their low fan speed settings go south sometime or another.
As for the repair...yes you can do it yourself, but it will involve removing the glove box and removing the blower motor to get to the resistor (that could take a while). It might be easier to just take it to a mechanic who specializes in Nissans and have the guy spend 30 minutes and fix it for you for $30-40.
Old Dec 23, 2000 | 02:08 PM
Originally posted by Eric L.
... ... As for the repair...yes you can do it yourself, but it will involve removing the glove box and removing the blower motor to get to the resistor (that could take a while). It might be easier to just take it to a mechanic who specializes in Nissans and have the guy spend 30 minutes and fix it for you for $30-40.
I respectfully disagree. I removed the blower resistor on my car just to see how difficult it was. Fast and easy. No need to touch the glovebox or the blower motor. Five minutes, start to finish.
Smackasmith
Feb 1, 2016 12:40 AM
14GmMax
Sep 17, 2015 09:08 PM
hntwhttail
Sep 12, 2015 03:43 PM
asianstyle
Sep 10, 2015 11:30 AM
2012Maximus
Sep 10, 2015 12:50 AM
