New Power antenna
New Power antenna
Just got a new power antenna to replace my broken one. Went to the dealer, they wanted $300 for a new one including installation. So I figured I would save some money, and do it myself. I took out the lining in the trunk near the antenna, but I still can't figure out how to disconenct it from the body. I can't seem to find how to unscrew it. Anyone got any ideas?
I imagine you know without a doubt... but to be on the safe side, you are certain that you need a motor and not a mast right? The mast is ~$24 and takes five minutes to install.
Sorry, I can't help with the motor install, never looked at it.
Ahhh... don't know about the motor. Gotta be some clips or something... if you call a service guy at a dealer he might feel an uncommon urge to help you out and tell you how.
The second post you made says "mast" but I think you meant motor. If you are trying to get the mast off, that is easy. You just use some needle nose pliers on the two grooves around the mast. Then just unscrew it. Patience is the key - don't want to do custom pin-striping.
