remote starter
Re: Re: remote starter
mine is a bulldog. don't know the model though.
Originally posted by 333matt333
if its dei my friends got the same problem.- i suspect the tach volts. input on these models is too sensitive. we installed his and it worked for a while and got worse over time.
What are the symptoms? Does it crank, but not start? Does it not enguage at all? Does it crank long enough for the car to start? Some auto starts have a crank time setting. If it's to short, your car will not catch and run. After your all warmed up, a quick crank starts it up, cold you may require a longer crank time. Most newer remote starts actually look for a run condition and adjust the crank time automatically.
it does crank, but not start. then after it is warm it will start on the second crank.
maxima297
Sep 30, 2015 03:32 PM
ToTheMax305
Sep 23, 2015 09:11 PM
