Guys with I-30 LSD Tranny On A Max ??
Old Oct 26, 2002 | 11:09 AM
matty's Avatar
How do you like it ?? How much wheel hopp do you get ?? You feel a difference in acceleration ?? Was it a worth while switch ??
-Matt
Old Oct 26, 2002 | 10:06 PM
matty's Avatar
I know people have done it...Is it worth the change ?? Does it bolt right up, and do I need different axcels ??
Old Oct 26, 2002 | 10:48 PM
I30tMikeD's Avatar
I have LSD on my I30t 5-speed. I don't know if you want my opinion or not?
It's not the greatest limited slip. I do notice it when accelerating hard through turns. Also when launching. Wheel hop? Not sure how LSD effects wheel hop, but when I run at the track wheel hop is not a real big problem for me. Don't know if that is because of my LSD or not. I do seem to be able to launch at higher RPM's than a Max w/o LSD.
Old Oct 26, 2002 | 10:54 PM
NismoSER's Avatar
LSD affects wheel hop little, if at all. Wheel hop will be held at bay with either stiffer motor mounts, suspension (stiffer shocks/struts), or better/different tires.
The diff will help a little with your launches, but you will notice it most when accelerating out of turns and just driving in bad weather in general.
In my SE-R, i have a viscous LSD, which undoubtedly has worn out thru the years, but I can really feel it when its wet out and I power thru turns No more stupid looking peg-leg burnouts either!
Old Oct 28, 2002 | 09:04 AM
matty's Avatar
Anyone else ?? Do I got with the LSD for my Max. ?? I have to change the drivers side axel and thats it right ??
-Matt
Old Oct 28, 2002 | 10:38 AM
SuDZ's Avatar
-Matt
Basicly that is it but while your at it I would obviously replace the clutch and get the flywheel checked out as well.
SuDZ
Old Oct 28, 2002 | 03:10 PM
97whitese5spd's Avatar
you can also reduce axle hop by lowering the air pressure in your front tires at the track.
-Mike
Ray229Harris
Sep 16, 2015 08:16 PM
seesole
Aug 26, 2015 11:22 AM
maxipower
Aug 21, 2015 11:10 AM
DayHeyZeus
Garage and Workshop
Aug 16, 2015 12:29 AM
Supragte
Aug 12, 2015 10:00 PM
