Apex WS rattling....
Old Oct 26, 2002 | 12:38 PM
Shoooter_j's Avatar
Any remedy for this problem? Through every little bump I can hear the exhaust bouncing around in the back.
Old Oct 26, 2002 | 02:23 PM
Vesaijan's Avatar
Re: Apex WS rattling....
I had this same problem. Go around to the back of you car and look along the passenger side of the muffler. You will notice the metal hanger is very close to the mounted part of the tow loop. If you press upward on the muffler, you'll notice they touch.
What I did is took a piece of 5/8 heater hose tubing (left over from installing my intake) and cut a line down the middle of it long ways. I then hotdog bunned it around the metal hanger on the muffler with the open end facing away from the tow loop. I then took three zip ties and tightened it down. The rubbery hose should keep from sliding if the zip ties are nice and tight. I cut the ends of the zip ties and viola! No more banging.
RL
Old Oct 26, 2002 | 02:28 PM
carnal_c30's Avatar
Former Sponsor
other thing to do is to replace the rubber hangars for the exhaust that would help too
Old Oct 26, 2002 | 03:31 PM
Shoooter_j's Avatar
you guys r the best
Thanx, I'll give the hose a try, then if that doesn't work, replace those rubber mounts!!
Old Oct 26, 2002 | 10:17 PM
dudevolley's Avatar
b4 you replace all the rubber exhaust hangars, you can just buy another one, preferrably a flat one and Zip tie it to the tow loop so the ratling stops.
Old Oct 27, 2002 | 02:44 AM
Aaron's Avatar
Langley AFB Sux
How about remove the bolts that hold that tow loop on.............really.......what are you going to need that for?
I took mine off......keep it in the trunk.
Aaron
Old Oct 27, 2002 | 07:17 AM
dudevolley's Avatar
Aaron
never thought of that...but that's a good idea too
Old Oct 27, 2002 | 01:10 PM
ivelweyz
Re: Re: Apex WS rattling....
RL
Great answer, when I got my WS installed the installer guy told about that and asked me if he can remove it. I said sure since those things are only used when the car is getting shipped Japan to tie it down...
Nathan
Jul 19, 2001 06:09 AM
2ndMAX
27
Apr 25, 2001 08:39 AM
MikeO
Nov 17, 2000 11:04 AM
Victim64
Nov 4, 2000 08:49 PM
