child car seats...
Old Oct 27, 2002 | 07:12 PM
Roman-dude's Avatar
child car seats...
Hey, I wonder if I could get an advice from you guys who use child car seats in your cars- which ones are you most satisfied with, both in terms of safety as well as the way they fit in the cars..
Old Oct 27, 2002 | 08:14 PM
StygianMax's Avatar
Re: child car seats...
Now here's a topic that doesn't come up much!
What age/weight/height is your child? There are different classes of car seats (e.g. babyseats are for kids who are <20lbs & boosters are typically for 20-40lbs). 5-point seatbelts are good for kids around 3-6 yrs. (I'm generalizing since all kids are different sizes & heights). I've got a 9 & almost-6 yr. old so I might be able to share some insight with you. Aside from that, I'd suggest Consumers Reports as a good place for reference info where a lot of different products are compared based on many factors. Your local library should have stacks of them.
Oh yeah, our Max started off as a family car but has morphed slightly over the past year.
Old Oct 27, 2002 | 08:22 PM
Roman-dude's Avatar
Re: Re: child car seats...
Yeah, it certainly doesn't. Well, I know about the different types of seats, so to phrase is better I am looking for the advice on the booster seats (20lbs and up). We have an 11-month boy and he's getting a bit too big for his infant seat. Based on what I've read, most people agree on 3-4 different seats, but I was wondering if anyone knew which ones fit better in Maximas than the others, as well as some insight on whether the kids like them or not.
BTW, great pic of the center console....
Old Oct 27, 2002 | 08:23 PM
BBaker025's Avatar
PM Redmaxpa007, he has the car seat that looks like a racing seat!
Old Oct 27, 2002 | 10:39 PM
VeeTec's Avatar
We used an Evenflo and a Century when we had our 97 SE, and they both fit quite well. I can't remember the models off hand, but there were no issues at all. The Century appears to have a better latch, where the 4 belts come together, but I am unfamiliar on actual test results.
Just make sure, with any seat, that you tighten the belt down as firmly as possible, so that there is NO play. Sometimes you can get a little more of a snug fit by placing your body weight on the seat, as you install it. Also make sure the belt is pulled all the way out, and that it clicks as it retracts, as you tighten the seat down, as it is locked from being pulled out.
You might want to do a search on child seat fitment and safety. I am sure their are published results online.
Old Oct 28, 2002 | 06:24 AM
Roman-dude's Avatar
Thanks!
Old Oct 28, 2002 | 06:51 AM
Aaron's Avatar
Langley AFB Sux
Any of the 5 point style. I think the one my 2 1/2 year old is in is either a graco or evenflo... My infant daughters is one of those as well....cant remember the makes. The 03 and up models...cars and car seats use the new "latch" system tho....much easier and safer.
Just make sure you hook them up like they say....put some weight on the seats as you retract the seat belt....no play is needed between the seatbelt/carseat.
I got the upper teather mounts from nissan (they mount on your rear speaker deck) Some newer maxes have them already.
Oh...and watch for recalls on child seats too.....
Aaron
Old Oct 28, 2002 | 08:32 AM
Roman-dude's Avatar
Aaron
thanks, RE: LATCH- did you just call your local dealer for that? How easy is that to install? I'm driving a '96, so it did not come with one..
thanks again
Old Oct 28, 2002 | 08:39 AM
deezo's Avatar
I have a 4 year old and he weighs about 42 pounds. I have a full booster seat that sit pretty low to the seat. It also has an piece of plastic on both sides so you can loop the seatbelt through it to make sure the belt is directly across my son's chest instead of being across his neck.
Old Oct 28, 2002 | 08:55 AM
kratz74's Avatar
Also make sure you use the seatbelt clip all the time. I am 6'5 and getting my son in and out-made me sell my 99 Max SE ltd edition and buy a van. Still have my 95 though. Can't add much to all the other good info already provided. I also use a 5 point seatbelt/seat for him.
Old Oct 28, 2002 | 09:12 AM
Aaron's Avatar
Langley AFB Sux
thanks again
I havent checked to see if there is a latch kit for our older cars
Aaron
Old Oct 28, 2002 | 09:56 AM
GreenSE's Avatar
I used the information on this site to choose. I bought a Cosco Omega which fits infants and toddlers from 5 to 80 lbs.
http://www.epinions.com/kifm-Baby_Eq...-Car_Seats-All
Old Oct 28, 2002 | 10:01 AM
Roman-dude's Avatar
thanks, how do you like it?
Old Oct 28, 2002 | 10:21 AM
GreenSE's Avatar
Re: Re: Re: child car seats...
The car seat is cool I bought it at Costco for approximately $110. It has 3 reclining positions, and uses 3 belts to form the 5 belt pattern. You can change the belt height by moving the back of the seat up or down, without having to take the belts out. Only one belt adjusts all the others. Handling the belts take a little practice to get used to since they are soft and tend to bend. It's installed in my Rodeo, I still haven't used it in the Maxima. I'll try it today in the Max and post the fitment results tomorrow (if I don't get a mind slip).
Old Oct 28, 2002 | 10:23 AM
jbreit's Avatar
we had an evenflow "snap in" for our son the first 9 months before he outgrew it....i was pleased with ours, and the "carry in" aspect is nice too....they snap onto carts at the grocery store and everything. For the larger seats that we switched to we have Cosco....one is a triad, the other is a touriva...same seat, but the plushness varies...the touriva is the "cheap one" but still ranked 4th by consumer reports last year (the triad was 3rd, and the top two aren't made anymore). i remedied the lack of plushness in the cheap one with some extra carpet foam behind the cover. we kept these rear facing till 1 year and turned them around...he was a trim 24# by then anyway. my only dislike was the recline level built into them is not adjustable. when we had the cosco's rear facing i rolled up a bath towel to put in the corner of the car seat, and then set the baby seat on top of that and drew it down tight....that way he was laying back a little more...otherwise it was almost straight up and down.
Old Oct 28, 2002 | 10:53 AM
timmax's Avatar
5 point important as a "safety mod"
One of the seats I use for 20-35 lbs is Century 2000 STE, it has a five point harness. Realistically, each child needs three different car seats until he's big enough to use the adult belt only:
1. The rear-facing snap in seat for infant
2. The front-facing Century 2000.
3. The "racing" seat/booster seat with built-in 5 point harness.
4. The racing seat without the built in harness, using just the car's 3 point seat belt. Even my 8-year old uses this, he can see out the car better.
All of these seats are available in a 5 point harness, which is more important than brand, price, or style. By the way, I haven't needed the tether but plan to get it soon. I would be very interested in a product that provided 5-point protection beyond the 40 lb limit the "racing" seat has.
Old Oct 28, 2002 | 02:25 PM
fst96se's Avatar
My 9 month old is just about to outgrow his rear facing seat...I too have been wondering what to get for him. Maybe a new car. My i30 is too low, and my Expy with 35" tires is too high....hmm. A minivan maybe? Um, no.
Old Oct 28, 2002 | 09:43 PM
VeeTec's Avatar
Aaron
No kidding! They recall seats quite frequently. Retailers should have a list of recalls.
Old Oct 29, 2002 | 05:06 AM
GreenSE's Avatar
Re: Re: Re: Re: child car seats...
... I'll try it today in the Max and post the fitment results tomorrow (if I don't get a mind slip).
I tried the seat in my Maxima and it fits good in the sides both front or rear facing. The middle seat however does not feel secure. I heard (and it makes sense) that the safest place for infants is the center of the backseat, but in the Maximas is very difficult to find a seat that fits good. I tried with and without the car seat base (it's removable for this model) but the hump in the center just won't allow a snug fit. I think the leather seats aren't helping since the car seat slides too much. My previous car seat (a Graco snap-in model) did not fit at the center either.
Old Oct 29, 2002 | 07:14 AM
Bags's Avatar
VG Ridah's Biatch Hoe
You mean this http://images.cardomain.com/installs...03_30_full.jpg
Old Oct 29, 2002 | 07:25 AM
redmaxpa007's Avatar
i SeE what you did therE
HEY!!
yes that is the seat..
Old Oct 29, 2002 | 07:44 AM
Bags's Avatar
Originally posted by redmaxpa007
HEY!!
well I am part of the .org search enigne
Old Oct 29, 2002 | 07:55 AM
true true
Old Oct 29, 2002 | 11:36 AM
Unregistered iL's Avatar
jay was offeneded
Old Oct 29, 2002 | 11:57 AM
Originally posted by Unregistered iL
jay was offeneded
so?
Old Oct 29, 2002 | 12:00 PM
so?
i had posted something and jay was deeply offended by it, so i had to edit it, hence me saying "jay was offeneded"
Old Oct 29, 2002 | 12:03 PM
oh...
tell him to go to counciling and get over..it
Old Oct 29, 2002 | 12:12 PM
nymjayjay's Avatar
I wasnt offended by it at all, dont mind him redmax he has mental problems
Old Oct 29, 2002 | 12:21 PM
mental... if he knows you.. he is definaltly mental...
Old Oct 29, 2002 | 12:31 PM
nymjayjay's Avatar
Old Oct 29, 2002 | 12:40 PM
don't be mad cause i found out what your newest mod is gonna be..
Old Oct 29, 2002 | 02:47 PM
Roman-dude's Avatar
thanks to all. I am practically set on Cosco Summit, if anyone is interested.
regards
Old Oct 29, 2002 | 02:49 PM
nymjayjay's Avatar
shush Mr. NA
Old Oct 29, 2002 | 05:46 PM
Bags's Avatar
regards
glad we were able to help
and this is redmax's next mod
Old Oct 30, 2002 | 04:28 AM
PUNCH BUGGIE Yellow..!!! no punch backs
MikesChevelle
Nov 23, 2024 11:17 AM
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
Balkins
Aug 12, 2015 06:39 AM
altome15
Aug 10, 2015 07:05 PM
