OEM front sway bar bushings?
Old Nov 1, 2002 | 06:11 AM
redmaxpa007's Avatar
i SeE what you did therE
FRONT END CONTROL ARM BUSHING SET and FRONT SWAY BAR FRAME BUSHING SET (PAIR)
scroll down to maimxas..
$35 + shipping.. not bad pricing
has anyone changed them? i know some peeps have them already but not installed..
Old Nov 1, 2002 | 06:24 AM
funnylittlman's Avatar
RedMax,
I did a thread on this on a different site, and everyone said that, and I quote,"Every little bit helps"
I talked w/ the guys down at Courtesy Nissan, whom sell this too, and they said that it does help if your old bushings are going. It does firm it up a bit in the front.
Old Nov 1, 2002 | 06:32 AM
Originally posted by funnylittlman
RedMax,
sounds like i will be getting some..
Old Nov 1, 2002 | 07:28 AM
njmaxseltd's Avatar
Got them on my car. Definately made a difference in body roll and steering response.
Old Nov 1, 2002 | 07:30 AM
how long did it take to install?
Old Nov 1, 2002 | 07:43 AM
mzmtg's Avatar
Minister of Silly Walks
I put poly endlink bushings on my swaybar. I got the universal Addco bushings for $7.99 at AutoZone. I had to cut them in half to get them to fit, but they worked great.
Add them to your list...
Old Nov 1, 2002 | 07:55 AM
njmaxseltd's Avatar
After your wheels are off, it's a 10 min job.
TIP: You must take both sides off in order to lift the bar up. Otherwise you'll be working against the force of the sway bar!
Old Nov 4, 2002 | 07:18 PM
joaquink's Avatar
¿Hablas Español?
I can't comment on the control arm bushings but for the endlingk and
FSB frame bushings here are some pointers from an install. Some of
this has been posted before but I didn't find it all in one place.
1.Do the endlink and frame bushings at the same time.
2.You need a 14mm socket to get all bolts off.
3.You can do each side one at a time or both at once. I found it to
be fairly easy to move the swaybar with only one side jacked up but
it would certainly be easier with both sides up.
4.Make sure you have solid jackstands in place and then use your
floor jack to lift the lower control arm a bit as you are loosening
the nuts. This will help keep the stress off of the nut as the
control arm is trying to drop when you loosen the endlink nuts.
5.Use a quality grease that is water resistant and grease the inside
of all bushings. I also greased the bar slightly after cleaning it
to make it easier to slide the bushings down. I don't know if this
is really necessary but it sure was easy to slide the bushing into
place.
6. Once everything is in place you can tighetn down the bolts. What
I didnt' figure out was how to follow the FSM recommendation that the
suspension be fully laden when tightening nuts over rubber parts. I
ended up tightening while the front was still jacked up.
7. The torque specs are:
Endlink bushing nuts: 12-16 ft/lbs.
FSM frame bushings : 36-43 ft/lbs.
Cheers,
JK
Old Nov 4, 2002 | 08:48 PM
BEJAY1's Avatar
Conecarver
The control arm bushings are a bitsh according to all the other posts I've seen. Be forewarned.
Old Nov 4, 2002 | 09:35 PM
97maxinMA's Avatar
I snapped the endlink with an air ratched at minimal torque... make sure you use some wd-40 or something comperable to losen up the bolts before your try pulling em off.
Note of refrence: Nissan is subsequently the only place you can get the end link from, no aftermarket companies make them ie: no Auto Zone or Napa.
As far as the bushings, i have energy suspension bushings on my endlink top and bottom and the sway bar . The steering is tighter/ more responsive at higher speeds compared to factory.
Besides, they were a total of 20 bucks?!?? why not.... its not like its serious cash...
Good luck
Matt93SE
May 24, 2019 02:58 PM
kingw323
20
Oct 21, 2015 08:36 AM
homeyclaus
Sep 3, 2015 06:15 PM
ef9
Aug 27, 2015 07:21 AM
jerrod99_se-l
Aug 10, 2015 12:07 AM
