Help with indiglo installation
Old Nov 1, 2002 | 04:47 PM
athlon omega's Avatar
The damn tachometer keeps sticking. I've tried everything and it still won't work properly. I already looked at that How-to section. Any advice? I've spent about 5 hours on this thing.
Old Nov 1, 2002 | 06:05 PM
Nevermind. I finally got the damn thing to work properly, but I had to take out the factory one.
Old Nov 1, 2002 | 06:08 PM
SLC I30t's Avatar
Re: Help with indiglo installation
well 1 of 3 things are happening
1. the clearance between your tach guage and tach needle is too tight so its sticking
2. The whole for the needle spindle isn't lined up correctly
3. The indiglo mat is swelling due to the heat from you dash lights
These don't ALWAYS happen to people when they use indiglo or reverse indiglos, but it does happen. The way to prevent #3 is to get lighted rings for your needles or back your needle up the post to give it the clearance is needs.
Old Nov 1, 2002 | 09:14 PM
Re: Re: Help with indiglo installation
Thanks. How would you back the needle up the post?
Old Nov 3, 2002 | 03:49 PM
SLC I30t's Avatar
Re: Re: Re: Help with indiglo installation
You have to remove the needle rest then turn the needle counter clockwise gently till it stops. MARK THIS SPOT where you can re-align the needle in a minute. Now keep turning the needle counter clockwise another full turn while doing this very very very gently apply a pulling pressure towards the top of the post (UP)and finish the turn without pulling the needle off the spindle. Now re align the needle on its new height to the previous marked spot and then turn the needle to about 3k or that 9 o clock position on the tach and reinsert the needle rest and your done. Good luck, don't sue me if you mess it up. thanks
MaxLife17
Jun 27, 2019 01:37 PM
Excalibur23
Oct 13, 2015 04:33 PM
Max8
Sep 22, 2015 02:53 PM
2kmaximel
Sep 16, 2015 03:19 PM
Johnny9595
Sep 3, 2015 05:18 AM
