High idle ( 1800 RPMS ) after spirited driving on the highway
Old Nov 6, 2002 | 09:16 PM
Bags's Avatar
VG Ridah's Biatch Hoe
Ok.. so it has been cold in atlanta lately.. my cold idle is high, but where it should be. after the engine warms up it settles back down to about 700. ( I set it that high )
Well tonight after driving on the highway above the posted speed limit, when I put it in "N" or "P" the idle shot up to like 1800 RPM's.
While in drive it was just above 1000 rpm's , high as well.
I pulled over to a gas station and checked to make sure the cable was not caught on something and even checked to make sure the floor mat was not pushing on the gas pedal.
The temp gauge was in about the center of the gague.
I will let it sit tonight and see if it is still doing it in the AM.
But I drove like 30 minutes and it was fine. It just seemed after the highway run it was out of whack
Any thoughts????
BTW.. CAI,Y-Pipe,MEVI,CAT-back
Old Nov 6, 2002 | 11:03 PM
dmontzsta's Avatar
Ford Only.
It is RPM
you could say RSPM
RPM=Revolution Per Minute
Not Revolution Per Minutes
Old Nov 6, 2002 | 11:08 PM
ThurzNite's Avatar
I've noticed it in altimas, sentras, and maximas...after driving hard (near redline) for some time, the car will idle funky...like hover around 1000 rpm for 2seconds, then dip down to where it's supposed to idle. This's really noticable with 5sp...drive @ 5000rpm for 20seconds, then hit the clutch. The rpms will drop, hover at 1000rpm, then drop again. It's funny cuz it happens in all mid 90s and newer Nissans I've driven.
Jae
Old Nov 6, 2002 | 11:09 PM
dmontzsta's Avatar
Ford Only.
grrrr.... it is RPM
Old Nov 7, 2002 | 05:54 AM
dwapenyi's Avatar
Since we're being finicky then it's RevolutionS Per Minute
DW
Originally posted by dmontzmax
It is RPM
you could say RSPM
Old Nov 7, 2002 | 06:28 AM
JAY25's Avatar
DW
Baggs two days ago I was doing routine maintenance on my car and I put everything back together and forgot to hook up the MAF air sensor to the car. I went on ahead and turned the car and the idle on the car jumpe up to 1500RPMS . I was definitely in a world of WTF is going on. My BOV was blowing the air back out since the car was boosting. Went back to the car and saw the CEL light. Right then I knew I forgot to hook up the MAF sensor to the car. I really hope your MAF is not gone bad. I doubt it but thats how my idle kept on going up and down.
Old Nov 7, 2002 | 07:00 AM
Bags's Avatar
dmon- RSPMS'MP'SSPMR
Thurz- It was like this for about 30 minutes... and like that when I turned the car off last night.. I gotta run and help a buddy work on his house so we will see if it is crazy this morning
BTW I am an AUTO I think it was clear just forgot to mention it
dwap-
Jay- I will look at my maf, but I have driven this speed before with out this happening. That is what gets me. Even with the VI I drove this speed a few times... so I do not know. And I have not unhooked my maf.. maybe I will test it
Thanks for the suggestions
Old Nov 7, 2002 | 07:02 AM
JAY25's Avatar
also ensure none of your hoses or cables are pinched on the throttle cable.
Old Nov 7, 2002 | 12:58 PM
dashingMax's Avatar
This has happened to me also after a spirited run.
However, it goes back down to 500-600 after a couple of minutes.
Once, it didn't. I turned off the engine & a 30 seconds later, I restart and the RPMS are back to normal
I did check things under the hood & everything seems to be hooked up okay!
Old Nov 7, 2002 | 02:51 PM
wnb007's Avatar
My car has the same idle problem. Mine will do it under normal conditions though. It will idle very high sometimes when I push in the clutch, I have to tap the gas when I stop to get it to idle back down. It does it about 90% of the time when I have the A/C on. But only about 10% of the time with the A/C off. I get tired of my car idling at 1800 at red lights. The guys at the Nissan dealer didn't have any ideas on what could be wrong.
Old Nov 7, 2002 | 03:40 PM
Bags's Avatar
well my car was fine this morning and all day
dashing- I will look for it and keep this in the brain housing group for future reference
wnb- thanks for the info..and nissan never knows what is wrong..lol
Old Nov 7, 2002 | 03:44 PM
wnb007's Avatar
Mine started idling a little higher and the over the corse of a year it just kept getting higher and higher, it is up to about 1850 now. I am glad it is winter and I don't need the A/C because I don't have the money to let Nissan play with it for $65 an hour to try to figure it out.
Old Nov 7, 2002 | 06:22 PM
njmaxseltd's Avatar
You've got to be kidding me? Dude, not good, get that thing fixed!
Old Nov 7, 2002 | 07:02 PM
gtr_rider's Avatar
192.168.1.1
1850!?!?!
Old Nov 7, 2002 | 09:08 PM
black5spdmax's Avatar
1850!?!?!
that is either going to smoke your torque converter or clutch (auto vs. manual)
Old Nov 7, 2002 | 10:06 PM
wnb007's Avatar
It mostly only idles like that if the air is on. I just have to tap the gas to make it idle down, which is still a pain. I have a manual so it isn't hurting anything, it just ****es me off when my stuff doesn't work right. I think it has to do with the computer.
Old Nov 8, 2002 | 12:01 PM
Bags's Avatar
man it happened again last night. With no high speed runs on the highway.
Do you have a MEVI? Or just a SC?
Did it happen with or with out the SC?
I have had my car over 2 years and this never happened before... but I put the mevi on about 3 months ago..so it might have something to do with that.
I am going to spend lots of time next week on this.. just trying to get as much info from you as possible
thanks
Old Nov 10, 2002 | 09:53 PM
dashingMax's Avatar
thanks
I do not have an MEVI.
Earlier today, I ran against a modded IS300 upto 130mph. *touch wood* It didn't happen this time, however my CEL light is back on. Same exact stupid P0420 code.
It could be the MEVI. Run an OBDII scan first and see if the ECU is throwing any "ghost" codes.
PS: IS300 was owned by the dashingMax
Old Nov 11, 2002 | 01:03 AM
DTR Maxima's Avatar
my car does the same thing baggs. but i havnt really noticed if its like that after spirited driving or not. its more or less just spur of the moment. my car usualy idols, around 700 in 1st 2nd D or R, but when sometimes when i put it in neutral or park it goes as high as 1700-2k
Old Nov 11, 2002 | 05:07 AM
dwapenyi's Avatar
Maybe clean the throttle body?? It's right next the IAC valve. Maybe the IAC is just sticking
DW
Old Nov 11, 2002 | 11:49 AM
Bags's Avatar
hmm.. well thanks dashingmax.. i will do that.. no CEL, but I will check the codes.. and 130 is fun huh?
dtr- when does it hapeen the most.. summer/fall/winter/spring? or is it just sparatic?
dwapenyi - yeah I will ook into that.. I cleaned mt TB when I changed my manifold.. but I will look and see if I missed a spot or if some gunk is stuck in there.. thanks for the suggestion
Old Nov 11, 2002 | 02:18 PM
DTR Maxima's Avatar
well...... its more or less sparatic, and i just got this maxima in august and noticed it about a month and a half later. although i have noticed it mostly occurs after i have been driving for a while, like mostly when i get home and put it in park i notice it, and when i go to my girlfriends house and put it in park it often happens.
im just as baffled as you, but it sucks cuz i cant let my car sit to long in park when its doing that, otherwise my gas miliage goes down the sh*tter
Old Nov 11, 2002 | 04:45 PM
sinewave's Avatar
I would suggest that you re-adjust your throttle cable. Tighten the adjusment nut until the throttle cam starts to move, then back off the nut 1-1/2 turns. While your at it, lube the cable.
Also, try cleaning the butterfly and throat of the throttle body with carb cleaner.
BTW: It's RPM's
Old Nov 11, 2002 | 04:58 PM
joaquink's Avatar
¿Hablas Español?
BTW: It's RPM's
See my post at the bottom here
In short - I had the same problem but with a 5spd.
Problem solved with : replace neutral/reverse switch & adjust of cable (not idle set screw).
lowpost99
Oct 26, 2025 06:53 PM
mvm062
Nov 30, 2020 09:00 AM
Maxima.KsA
May 15, 2020 04:14 PM
Maxima30
Sep 7, 2015 06:13 PM
Justin Kroll
Sep 2, 2015 11:06 AM
