ECU code 03-02 EGR System Hi/Low Flow
Old Nov 12, 2002 | 11:50 AM
myamin's Avatar
Hi -
I get this code intermittently. Does it have anything to do with my new mod of cold air intake? In some of my searches it was suggested to clean my IACV.
Any ideas?
Thanks,
Mo
Old Nov 12, 2002 | 01:38 PM
Jamsan's Avatar
DTC 0302
Diagnostic Trouble Code 0302 points to a problem with the Exhaust Gas Recirculation system.
The malfunction isdetected by the Engine Control Module when no EGR flow is detected under conditions which call for EGR.
Possible causes include:
- The electrical harness or connectors (valve circuit open or shorted)
- The EGR valve is stuck closed
- Weak or dead battery
- The EGR passage is clogged
- Faulty EGR temperature sensor circuit
- A leak somewhere in the exhaust system
The EGR Volume Control Valve may be tested with an ohmmeter. Disconnect the electrical connector. Looking at
the connector half which is attached to the EGRVCV with the latch at the 12 o'clock position you will see two
rows of three terminals. The top row is numbered 1-3, right to left. The bottom row is numbered 4-6, right to
left. Measure the resistance between these terminal pairs:
2 1
2 3
5 4
5 6
... all resistance values should be 20.9-23.1 ohms at 68 degrees F.
Reconnect the EGRVCV connector halves. Turn the ignition switch ON OFF repeatedly. Verify that the EGRVCV
shaft moves smoothly forward backward according to the ignition switch position.
The Exhaust Gas Temperature Sensor may be tested with an ohmmeter. The specifications are ...
- at 32 degrees F, 0.68-1.11 Megohms
- at 122 degrees F, 0.09-0.12 Megohms
- at 212 degrees F, 0.017-0.024 Megohms
Old Nov 12, 2002 | 05:08 PM
myamin's Avatar
Jamsan:
Thanks!
Mohmd.
Originally posted by Jamsan
DTC 0302
2 1
2 3
5 4
5 6
QueensMAX
Sep 15, 2015 04:14 AM
dcam0326
Sep 7, 2015 07:26 AM
mix master
Sep 4, 2015 05:50 PM
Justin Kroll
Sep 2, 2015 11:06 AM
