Replacing Airbags
Old Nov 13, 2002 | 10:53 PM
Maxima81's Avatar
Replacing Airbags
Hi,
Anyone here familiar on replacing the airbags for a 95 Maxima? (Need to replace both after accident).
What parts am I looking for and how hard is it to actually replace?
I assume for the passenger's side it's just the unit with the cover?
For the driver's side, is it also just a unit that makes up the center piece (the part to press for the horn), or is it actually the entire steering wheel?
Also, I know I will need the control module (goes under the center compartment, under the rear center divider?)
Any other pieces I should know about?
Thanks in advance.
Old Nov 14, 2002 | 12:25 AM
96BLUMAX's Avatar
Well I would say your best bet is a haynes manual. If you need a driver side airbag and or steering wheel I can sell you that.
Old Nov 14, 2002 | 06:15 AM
njmaxseltd's Avatar
Let a certified Air Bag (SRS) mechanic put that system back.
You can't reset it on your own. You need to make sure every sensor is OK first otherwise as soon as you power it up, they'll explode again. If your sitting in the car when that happens, your not going to be happy.
Check with your local body shop, they usually have one guy specifically trained to reset the SRS systems.
Old Nov 14, 2002 | 06:53 AM
pezking4's Avatar
And this is going to cost a lot of money btw.
Old Nov 14, 2002 | 07:48 AM
ladeesman's Avatar
Would you know about that Les?
Old Nov 14, 2002 | 09:06 PM
96shogunmax's Avatar
I got a 95-96 black wheel and airbag ill sell you. email me if you want it. wayne19_82@hotmail.com
PH98I30
29
Feb 10, 2025 12:03 PM
mvm062
Nov 30, 2020 09:00 AM
dvcamp
Sep 18, 2015 10:17 AM
dcam0326
Sep 8, 2015 11:02 PM
Maxima30
Sep 7, 2015 06:13 PM
