Something rattling under my car?
Old Nov 14, 2002 | 09:13 AM
redmax95se's Avatar
My car is stock underneath. Lately my car is making rattling noises under my car. Sounds like metal maybe. Sounds comming from the front underneath my auto shifter. Wats happening can how much would it cost to fix. Kinda ****ing me off. Not that noisey but when i hit bumps i can hear it. ahhhhh help.
Old Nov 14, 2002 | 10:24 AM
heems27's Avatar
It might be the heat shield to your cat. If that's the case, just remove it. It also might be a loose O2 sensor right after the cat. Good luck!
Old Nov 14, 2002 | 10:46 AM
SuDZ's Avatar
I had a similiar problem with a exhaust hanger, it came a little loose and was hitting the heat sheild. Just had to adjust it a bit, total cost $0.00
SuDZ
Old Nov 14, 2002 | 11:53 AM
JAIMECBR900's Avatar
Check to see if this gets you where you want to go....
http://forums.maxima.org/showthread....hreadid=166073
Old Nov 14, 2002 | 12:09 PM
StygianMax's Avatar
Love your rims man! Don't see too many folks with RSEs.
Old Nov 14, 2002 | 12:15 PM
Unibomber's Avatar
heat shields are useless
Old Nov 14, 2002 | 12:16 PM
fast97maxse's Avatar
The heat shield on my cat just fell right off.
Didn't make any noise til I ran over it.
But I had rattling/knocking noise over bumps.
Turns out two of the hangers had rusted off.
The garage across the street from work did a temp fix with wire
and then a real fix a bit later.
I think it cost about $65 to get it done.
(and my dealer said I'd need to replace the whole exhaust system - the good-fer-nothing-bums).
Redmax - with a 95, it's a good bet you have some hangers rusted out.
Try to get underneath and give the exhaust a shake, see what happens.
(wear work gloves or be sure it's cool).
Or find a friendly garage and ask if you can just put it on the lift for a quick check...
let us know what happens.
Hondarydr
Dec 30, 2024 06:15 PM
MikesChevelle
Nov 23, 2024 11:17 AM
Lakersallday24
Jun 16, 2019 01:35 AM
kingw323
20
Oct 21, 2015 08:36 AM
