how many of you think my alternator is going bad?
i looked up a few posts about alternators. i might get mine replaced under the recall. but here are the symptoms: 1. when cold starting the engine barely stays alive revving at about 400rpm and occasionally stalling out unless i blip the throttle a few times. 2. the headslights go slightly dim when i'm at idle or neutral and i'm holding the car with the brake. 3. faint whining sound coming from the engine bay when the car is idling. what do you guys think? it seems like the symptoms sound similar to other people's experiences with alternators...
Re: how many of you think my alternator is going bad?
Re: Re: how many of you think my alternator is going bad?
Originally posted by iwannabmw
I would look into why your car is idling at 400 rpm first. When were things like the fuel filter changed, sparkplugs done, throttle body and IACV cleaned? All those can affect your idle. If your engine is only turning 400 rpm, the alternator will be barely be able to provide any juice to run the electrical system.
A full tune-up needs to be done.
Easy way to see if your altenator is bad would be disconecting the battery while the engine is running.
You'll know if your altenatoris generating electricity.
Auto Zone can do free check also.
It's a FREE new alternator!!
I WISH I could get a new one in the recall, but my Max was
made in January 1997, a month before the alternators' were affected.
personally, I think I need a new one...
cheers!
FLO_BOY
Faint whining sound? Sort of like a quiet supercharger??
Definitely the ALT.
Mine did that, too. Whined for like 6 months b/c I wasn't sure if it was the ALT of the water pump. I replaced the pump and the whine was still there
DW
Definitely the ALT.
DW
[B . . . . faint whining sound coming from the engine bay when the car is idling . . [/B]
Originally posted by Stephen Max
Yikes!! Are you sure about that? I thought that was a good way to ruin your ECM!
what i will do is reset my ECU and check my battery. i've since filled up with regular gasoline and it still idles low. that is also when i started noticing more and more that my lights dim. and my idle rises slightly (to 600rpm) when i turn the heater fan on. if i remember correctly, this didn't used to happen except for the AC compressor. and more and more i notice the faint whining sound coming from the engine on a clear silent night. i figure it stalls in the morning when i first crank it because there's not enough juice to keep it firing. anyone have any ideas? i'm going to make an appointment to nissan right now. watch them flame my mods when i roll in.
Definitely the ALT.
DW
Definitely the ALT.
DW
I have this problem...it'll only get worse...please let me know what
Nissan says -- also, I think that my problem is bad coil packs.
good luck!
FLO_BOY
Originally posted by Jeff92se
Are you SURE you weren't experimenting w/ octane booster or something?
Since our cars are so electronic nowadays, a voltage drop from the ALT will hurt everything. the ECU will read the O2s slightly off kilter, the MAF may be a bit off in it's air reading etc. Also, your battery is probably slowly dying b/c the ALT can't get a high enough voltage to charge it anymore.
DW
DW
TallTom
57
Oct 14, 2025 05:16 PM
RealityCheck
Oct 2, 2015 06:34 PM
Andy29
Sep 29, 2015 05:32 AM
