need help aiming foglights
sup guys, i need some help aiming my factory fog lights. i know there is a screw on the back for adjustments, but which way do i turn the screw to aim the lamp up, and which way for down??
thanks
Cris
thanks
Cris
If you park your car 25 feet from a wall, make a mark where your light is hitting now, crawl under there and crank on it a few times (remember which way you turned it!!
), and check the wall again. Through process of elimination you should be able to figure it out.
This doesn't exactly answer your question, but you might find some useful info here. I found it in the
FAQ section
How do I reaim my headlights / foglights?
The adjustment bolt closer to the parking/corner lights (outboard of the vehicle) is for the up/down aiming of the headlamp. The one further inboard is to control the right/left aiming of the lamp. You'll need a 10mm wrench to perform the aiming task.
To do the height adjustment, park your car so that the headlamp lens faces are about 25 feet from a wall. This wall should be perpendicular to the ground and level in all aspects. Measure the distance from the center of your headlamps to the ground. Mark this dimension on the wall. From this mark, move down 3.75" to 4" and make another mark. Begin to turn the adjustment bolt so that the centers of your low beam patterns land on that second mark that you made. As for your right to left adjustment, mark the centers vertically and aim so that they point straight out. Bear in mind that sometimes adjusting the right/left bolt can change the setting of the height adjustment slightly.
By the way, the foglamps can be aimed the same way. The foglights are 8mm.
Credit: Albertt and j-95G (for the foglamp info)
), and check the wall again. Through process of elimination you should be able to figure it out.This doesn't exactly answer your question, but you might find some useful info here. I found it in the
FAQ section
Damn ... there was a link posted a couple of days ago to a really good articles with a diagram of how to re-aim your head and fog lights and I can't find it.
I'll keep on searching and add it to the FAQs.
thanks guys, but all i need to do is just aim them up, b/c now there is dark "gap" of light b/t where my headlights hit the road and my fogs.
but if you can find the nice write up w/ pics plz let me know.
thanks
Cris
thanks
Cris
Yes!
Lite - great taste, less filling: http://www.autooptiks.com/aiming.html
Regular - awesome taste, very filling: http://lighting.mbz.org/tech/aim/
But if you want to get rid of the "dark zone", just adjust the auxiliary lamp up slightly.
Heat0212
Oct 24, 2020 12:36 AM
ah2002
Mar 9, 2016 01:42 PM
ricky7780
Nov 3, 2015 03:22 PM
Hdnseek
Sep 9, 2015 05:55 AM
