Fog BULB replacement Help!
Bought some bulbs but having problems installing. I've ran a search but the closest thing to helping is a site which seems to be dead:
<http://integra.vtec.net/geeser/megamax/foglight.html>
Can anyone help with instructions on how to install. From looking at the bulbs, I was begining to think what I have is the wrong size, but it says "H3" and comparing it to Customaximas h3 pics on his site, it looks like the same bulb, with the same funny little "curled" metal piece at the end of the wire. Our factor H3's don't look like that at the end of the wire, it is flat not "curled". Help!
Originally posted by amixam98
Just follow the white string til you get to the end. There should be squarish metal piece at the end. Just give it a good pull and it will come out.
Ok. Well after I get that piece off, how will the aftermarket bulb's piece fit if it ISN'T flat like the OEM bulbs are? This is the real head banger for me. Even if I get the OEM Bulb out, the Aftermarket piece doesn't look like it was made to fit, but it IS an H3 bulb.
Originally posted by Capitone
Thanks amixam98!
Thanks amixam98!
It is flat (I think it's called a connector). What you should do is look at your replacement so you know where to pull out the OEM light bulb. Your replacement should look the same as the OEM.
Ooooooooooh......You know...I don't have the fog bulbs in front of me to confirm, BUT, I think a flicker of understanding just materialized. I think I've been looking at what actually connects the bulbs all wrong. I tell you, little understanding goes a LONG way. Thanks Again amixam98. That just might do it!
I guess my question now is, Do they make different versions of the H3 bulb? Because from the looks of things, the version I have will not "mate" with the factory connection.
Anyone?
Anyone?
Still having problems. That flat square piece on the OEM came out, but the "crimp" end of the Aftermarket (AM) is not fitting anywhere. Am I supposed to pull the crimp off of the AM bulb (exposing the bare wire) and replace it with the OEM bulb's flat piece? As it stands now just look'n at it, thats the only way it will fit?
Put the OEM next to the AM bulb and see if they match, which they should. You should have the squarish metal piece on the AM bulb which should slide right in.
http://cgi.ebay.com/ebaymotors/ws/eB...tem=1871800643
Here's what a H3 should look like. It's the last picture.
http://www.custommaxima.com/PiaaFogLight.htm
That is what my bulb looks like, the yellow ION's. Whats up with that?
Originally posted by njmaxseltd
The PIAA and Ebay bubls are exactly the same....
Did you damage the OEM H3's when you took them out?
Adaptors!! I knew something was screwy! I called the seller of AM's and she tells me that I needed $1 adapters for these bulbs. This mysterious "crimp" I've been raving about is called a "bullet crimp". Apparently they use this sort of connect for H3's in another country or something. Well, now that I know Im not crazy, I'll just go ahead and purchase these adaptors. Thanks Again for all your help amixam98!!
Originally posted by TheSoundSoldier
Capitone, might I ask what kind of bulbs you have? I just got the PIAA H3 fogs, they're waiting to be installed....
YourLocalAsian
08-17-2015 02:33 PM
Viralkill
08-17-2015 10:54 AM
MikesChevelle
08-06-2015 11:36 AM
