Installed Addco RSB -
Easy install. 8 bolts and you're done. I didn't remove the emergency brake bolts, don't see why you would.
My only concern is why the hell did I wait so long to get one of these? I put it off and put it off in hopes of an incredible deal. Well I finally got an incredible deal thanks to maxed out but I wish I had just bought one sooner. Anyone who's contemplating it, just do it! It makes me want to take on ramps and off ramps just for the sake of doing so. I love it. It's like a new car.
I use to have one and I miss the flat cornering. Things I didn't like about the RSB was that it increased ride harshness (17lbs more unsprung weight on the beam) and it seemed to bind the trailing arms when turning over bumpy surfaces causing more of the "rocking" our Maximas are known for. The rear suspension feels like it's able to do more without the bar. It definately leans a lot more, but it seems to be more controllable. The RSB isn't near as noticeable with lowering springs.
Dave
Dave
Dave
Dave
My car is not lowered, and the rocking is eliminated. The best way to describe it is imagine taking a left turning on or off ramp at about 45mph. Just when you want to keep going like you're in a F1 car, the Maxima's rear left wheel feels like its going to come up and hit you in the left shoulder. Well, that feeling is gone. You can keep your foot on the gas and the car stays even in the back.
I mean, it doesn't turn a Maxima SE into an M3 with the turn of a few bolts, but it's about as good as it gets without major suspension tuning.
My next curiousity is would a rear strut bar be of any worth with this set up?
Sorry if this is obvious, but I'm new here. Give me a break!!
RSB on this forum usually refers to rear stabalizer bar or rear anitsway bar. It goes underneath the car and attaches to the rear axle and trailing arms. A RSTB usually refers to rear strut tower brace. Hope that helps.
Re: Installed Addco RSB -
having it in your garage and not able to install because u don't have the proper tools to keep the car up and install...and car is lowered which makes it even harder without proper tools
On an unlowered the Maxima, the RSB makes a HUGE difference. I completely agree. However once you start lowering the center of gravity, the RSB becomes less and less effective depending on your drop. When I had my Intrax with my Addco sway bar, the car felt planted, but a bit "skiddish" around bumpy turns. I could feel the rear beam working really hard (no noises). I took the bar off simply as an experiment and I immediately noticed the rear suspension working again. As I went around tight 90 degree turns at 25-35mph, the car turned in much quicker. It leaned marginally more, but the suspension was working as Nissan intended (excellent turn-in response). Another benefit was a softer ride because the nearly 20lb bar wasn't suspended from the rear beam. I've got H&Rs now (.4" higher in the back than Intrax) and my car does lean into turns slightly more, but it never feels out of control or tippy. I prefer a little more lean and a better overall feel of control vs a darty setup which sometimes can surprise you (oversteer). Motor Trend actually got better handling numbers without the RSB on the Stillen SC Maxima. They did note that the RSB Maxima did feel better though.
FYI, the beam does have a RSB for stock. It runs thru the middle of the beam (look underneath) and attaches to the trailing arms. The bar is actully very thick too at .75". Pretty much the beam is one big RSB.
Dave
Dave
Re: Re: Installed Addco RSB -
Originally posted by meccanoble
u know what's worst than that?
It was a little tight because he was lowered too, but we managed.
should i get it?
Dave
Dave
thatcollegestudent
18
10-05-2015 02:29 PM
