what happens when you hit the rev limiter?
I was doing a burnout for 10sec w/the gas all the way down. The needle didn't bounce, it just stayed a few mm above redline. No problems.
And today, i was pulling into the freeway in 2nd gear, hit redline for 1 sec, but didn't feel the same jerk you get when you hit the 118mph speed limiter (yeah, did that one a few times too!)
Just sharing my experience. anybody else hit redline for more than 1sec? any problems?
Jae
Jae
Re: what happens when you hit the rev limiter?
when you hit the limiter it just bounces off...and if you keep on the gas, it keeps bouncing off the limiter, while going at the same speed.
when you are at 118mph you should not hit a limiter, your car should go a lot faster than that, something is wrong with your car if it cut off at that speed. anyways, when your car has a governor in it (some max's do, some don't) your fuel gets cut off, not bouncing off the limiter so it would feel a bit different.
I have a 1997 GXE 5sp...Pretty darn sure there's a speed limiter that's around 118 (hit it about once a week...yeah, I like driving fast!) And when I hit 118, it feels like I hit a wall and the car decelerates as if there was no gas...down to about 110, and then it accelerates back to 118 (next time I will note what rpm I hit the speed limiter)
When I hit the rev limiter, the needle doesn't bounce. It stays tacked to it's position. How does the ecu limit the rpm?
Jae
Jae
Jae
Jae
i thought all 5spds didn't have a governor, i guess i was wrong.
well my 99 5spd doesn't have a governor for sure, and goes quite a bit past that, however i haven't hit the top speed yet cause i don't drive on the highway during daily driving so i don't get a chance, but i have went past 118mph before.
I think you can hang out in the redline for a while. I have a 5spd and when I burnout, mine hits redline and stays there. It doesn't bounce. I try to continue into 2nd but my clutch is no good
I know for a fact mine doesn't have a speed limiter. Its a 95 SE, and I have hit 137 in it. There were 2 other people in it so it wouldn't go much more. The only performance mod I've done is a Pop Charger. I think i can hit 140 if the car was empty.
Jae
Jae
try it without burning out, or try it in second gear, it will bounce off the rev limiter.
Originally posted by Dev
burning out is a little different, cause your car isn't really going that fast, when the tires catch, the rpms drop.
Couldn't say for top speed... never went past 127 or so...
Originally posted by pocketrocket
I hit the rev limiter once on my automagic, going from 1>2 while manual shifting, it's basically bouncy-bouncy ....
It is at WOT then blub blub blub...
D
It wasn't posted by brian... try the looking The new ben's ecu mod by Ben Garner aka mzmgt...
Originally posted by 95emeraldgxe
look for search for brianv ecu mod.......all it takes is a simple snip of a wire and you dont got a limiter anymore
I have a 95 SE 5-speed and I have hit 130 at 5600 RPM. I am guessing that I would be at about 135mph at redline if I had the room to keep going. 135mph is pretty damn fast though.
gotta listen for that radar detector too
Concerned
Im kind of concerned, i got a 97 SE 5spd a week back and was testing it out and hit some sort of limited at 118 in 4th...i was told SEs dont have limiters...it could have been the rev limiter as i wasnt staring at the tach but seems odd it was at 118. Whats going on here? Im positive its SE by the 5spd, loaded, spoiler, wheels, steering wheel, gauges, etc....thanks!
Re: Concerned
sounds like you have a GXE to me if you hit the speed limiter at 118
Very Concerned
How can I have a GXE? Sunroof, 5spd, leather, Bose, white gauges, perforated wheel, rims, spoiler...how is this a GXE? Can 4th go beyond 118? Whats going on!? If its a GXE, i need to return it because they sold me it illegally as an SE! I dont see how it could possibly be an SE. The VIN says its an SE, I also just got the altranator redone and youd think theyd notice if it was a GXE! AH!!
Jae
Jae
Re: Very Concerned
Bad Newbies
Search Search Search.
All 4th gen maxima's that are not SE's or don't have the C&C package have a speed limiter. This means that most GLE's don't because most of them have the C&C package. This also means that it is possible to have a GXE with no limiter, as it was possible to purchase them with the C&C package, but many of them do. And yes, it is a fuel based govenor.
As far as the rev limiter, I gather it works like most other rev limiters, and should be bouncy. Why yours just stayed in one spot, it odd I suppose. It could be that you approached it so slow, that there really was no bounce. Most people feel the bounce running the quarter or something where they HIT redline.
Re: Bad Newbies
Re: Concerned
Re: Re: Concerned
Originally posted by CaLSoNiC
You were in 4th gear thats why. In my car in 4th I get to only around 120... so remember to shift next time.
Derek
Re: Bad Newbies
Yeah, when I hit 118mph, I was in 5th gear. I don't think 4th goes that high, but I don't have my FSM on me right now
Jae
Re: Re: Concerned
DC_Juggernaut
Sep 28, 2015 04:07 PM
