problem with max
Old Nov 30, 2002 | 06:09 PM
Max6856's Avatar
problem with max
just installed a new battery... resetted the ecu.... now my car idles at 4000 rpm.... even when its freezing cold in the morning... and it takes 10 trys to start it...and it viberates on drive.... HELPP!!??? anyone please
thanks
Old Nov 30, 2002 | 07:08 PM
kratz74's Avatar
Did you bump the electronic clip by the air intake? Check those connections. Obviously the battery didn't do it...you had to have bumped something. Maybe check your codes on the computer See the FAQ for that).
Old Dec 1, 2002 | 08:31 AM
Max6856's Avatar
i dont think thats it... wouldnt i have a check engine light if i cliped that off?? what else could it be.... DAMIT!!!
Old Dec 1, 2002 | 08:37 AM
rguida's Avatar
i just changed the alternator and battery on my car and now it drops down to around that number when I take the foot off the gas, but then it jumps up after a second or two....maybe our cars do not like running with new electricity?
Old Dec 1, 2002 | 04:15 PM
iwannabmw's Avatar
Re: problem with max
thanks
Please tell me you mean 400 rpm
When was the last tune-up and how many miles on the car now?
Old Dec 1, 2002 | 07:10 PM
Max6856's Avatar
oops... i do mean 400 RPM.... sorry about that!!!
Old Dec 1, 2002 | 07:12 PM
Max6856's Avatar
I JUST GOT A CHECK ENGINE LIGHT!!! DAMIT IM HAVING SECOND THOUGHTS ABOUT THESE CARS!!!
IN THE PAST 1 MONTH I HAVE
CHANGED ALL SIX FUEL INJECTORS, ALL SIX IGNITION COILS, 60K SERVICE FROM THE DEALER, FULL TUNE-UP, NEW BATTERY, NEW SUSPENSION, NEW BRAKES, AND A WHOLE LOT OF OTHER SHIET.. AND I RESET MY ECU... STILL I HAVE MORE PROBLEMS... THE CAR IS GETTING BAD GAS MILEAGE(11-12 MPG) CHECK ENGINE LIGHT IS ON... IDLES AT 400 RPM AT IDLE. THE CAR DOESNT KNOW ITS COLD OUTSIDE WHEN ITS COLD I START IT AND IT SHUTS OFF.. I HAVE TO PRESS THE ACCELERATOR ALL THE WAY FOR 5 SECS FOR IT TO START.... DAMMIT :-( HAD IT DIAGNOSED COUPLE OF MONTHS BACK AND IT WAS ALL FINE EXCEPT MULTIPLE CYLINDER MISFIRE.. SO I HAD ALL THAT DONE
LEME KNOW WHAT U GUYS THINK I SHOOULD DO.. OR WHAT CAN BE MAKING MY CAR DO THIS
Old Dec 1, 2002 | 09:05 PM
iwannabmw's Avatar
What code came up?? That should help narrow it down right there.
Old Dec 1, 2002 | 09:44 PM
tm96max's Avatar
2 weekends ago I installed a fog light kit. The instructions said to disconnect the battery. After I was done and reconnected the battery, the maxima would not start. It would crank over just fine but would not start. I reset the computer and after a few more tries it started and ran fine. I have had no problems since then. I am not sure if it was the resetting of the computer that finally made it work or not though. Maybe worth a try though.
Troy
Old Dec 1, 2002 | 09:58 PM
Max6856's Avatar
how do i figure out the code.... i dont wanna take it to the dealer.. cause i got a diagnose like 2 times in da past 4 months cant afford to get another one
Old Dec 1, 2002 | 10:04 PM
tm96max's Avatar
Go here first : http://vbxmaxima.8m.com/ecudecoder.html
then go here: http://vbxmaxima.8m.com/ecu.html
Troy
Old Dec 1, 2002 | 10:49 PM
Max6856's Avatar
Troy
hey...
thanks man.. ill try this tommorw morning.
Old Jan 17, 2003 | 10:22 AM
jmax
Did you ever solve this problem. I have a multiple cyl misfire, 0701 also. Dealer insists I need 6 new coils. But my mileage is good and car runs pretty dang smooth. The search I performed came up with many threads. But no one ever says what finally fixed the problem.
Old Jan 17, 2003 | 12:02 PM
Max6856's Avatar
i raised the idle ... that helped and i had to drive the car for about 200 miles now it seems to be fine.
i got 6 ignition coils ... if u want any pm me with an offer.
Old Jan 18, 2003 | 07:26 AM
jmax
I don't mean to sound dumb but did you adjust the idle by turning the screw on the PCM under the dash back to the right? Or did you do it manually under the hood?
Old Jan 18, 2003 | 12:46 PM
Kevlo911's Avatar
Kevlo for President
clean ur throtle body, and replace fuel filter it shoould help
if u need to know how to go here http://www.motorvate.ca/
http://vbxmaxima.8m.com/fuelfilter.html
Old Jan 18, 2003 | 02:57 PM
njmaxseltd's Avatar
He still hasn't posted the code from the check engine light.....
Old Jan 18, 2003 | 03:56 PM
Lime's Avatar
yup.
second thoughts because he can't work on a car but tried! Ooops...I am mean. Sorry.
Old Jan 19, 2003 | 08:07 AM
jmax
Maybe, he just has not had the time yet? Besides that, it's cold as $h!t where I am.
Old Jan 20, 2003 | 08:10 AM
Max6856's Avatar
i adjusted the idle screw from the hood.... and its all fine now. wouldnt checking for codes reset my ecu.
Old Jan 20, 2003 | 08:40 AM
Max6856's Avatar
i got CODE : 0505 ... No Failure Recorded/Detected
BUT when i tried turning the scew back it wouldnt stop
Old Jan 20, 2003 | 08:49 AM
MAXXIMIZEDMAX97's Avatar
I brought my Max to the dealership this morning, and the guy just called me up, and told me i needed new ignition coils because some of mine are burnt out....Now What are ignition coils, and how much do they go for each? and would i be able to buy them off you, and have the dealership install them for me, if i just pay labor, or are these something i can install myself?...PLEASE HELP!
ChRiS
Old Jan 20, 2003 | 10:14 AM
Max6856's Avatar
Originally posted by MAXXIMIZEDMAX97
I brought my Max to the dealership this morning, and the guy just called me up, and told me i needed new ignition coils because some of mine are burnt out....Now What are ignition coils, and how much do they go for each? and would i be able to buy them off you, and have the dealership install them for me, if i just pay labor, or are these something i can install myself?...PLEASE HELP! p
ChRiS
igntion coils are coils that give electricity to the spark plugs, they are right on top of the spark plugs. i am a 100% sure u can change them yourself... u just need the instrutions... i didnt need the but u might be needing them because u dont even know what they are... anyways if the dealer tells u to replace all of them dont listen to them... replace just the defective ones... i have 6 igntion coils in my garage.. HANSHIN which are the best ones... new ones are about around 100 bucks each .. and ill sell you 6 for $150+Shipping they are all in great working condition. PM me if your interested.
matts95max
Apr 23, 2025 10:44 AM
pktaske
May 6, 2016 07:49 AM
captchaos
Mar 15, 2016 12:18 PM
MaxLife17
Sep 8, 2015 02:36 PM
pktaske
Sep 4, 2015 08:40 AM
