Suspension Question
Suspension Question
Ever since I got my 17" rims put on I have to endure the great feeling of every little bump on the road so I was wondering if there is an suspension upgrade that I could get to get rid of that bumpy feeling?
Re: Suspension Question
Is your suspension stock??
Re: Re: Suspension Question
Originally posted by I30tMikeD
Your tires could have a lot to do with it. I had just 17" rims with no lowering springs for a while. The ride was just barly bumpier than stock. I am running 235/45 potenza RE950's.
Re: Re: Re: Suspension Question
Yes it's stock
Yes it's stock
I got 17 inchers also and it made my ride stiffer because of the low profile tires. Yes i will upgrade my suspension to Kyb agx's with sprints im going for the lowest drop but will be alot more rougher with the stock suspension for sure. Dont mind the rough ride because of the great handling you'll get out of it.
Originally posted by 95Max
New struts will help but not eliminate the bumps. I recommend getting KYB GR-2. I got mine at Shox.com
Yes/No...Ok yes, no more float feeling, small bumps no longer an issue. One the no side; I lowered the car with ST springs. They are stiff if not slightly stiffer then Eibach...so you know it when you hit large bumps.
pears
09-18-2015 05:25 AM
Violator
09-09-2015 10:14 AM
