suspension question
suspension question
Guys I'm getting coilovers in a week, and I had sprints before, I'm rolling on my stock suspension now, and the camber is bad \ /
Is there any way I can adjust the camber, because on hard turns, the tire is on its sidewall =/
Re: suspension question
Camber is not adjustable on our cars. Does it just look bad, or have you had it checked?
Re: Re: suspension question
When you raise the suspension back up to stock height, the toe is affected as well as camber. Your toe may be so far off that you are having problems.
You have already forgotten rule #1:
Whenever you take apart the suspension, you need to get an alignment afterwards.
I know I need an alignment but it seems like a waste to pay 50 bucks when im redoing the suspension within a week.
Then quit whining and deal with it for a week...
blah... u missed the point oh mister moderator sir!... I was afraid it's dangerous to drive like this... sheesh... someone's crabby
it probably isnt very stable bro
take it slow for the week . be careful
after you swap out the parts again, go to the shop and have them straighten you out. youll be ok again
go slow this week
go slow this week
go slow this week
go slow this week
1. Jack up front end.
2. Loosen (but do not remove) the bolts that hold the spindle to the strut.
3. Grab ahold of brake rotor (or wheel) and pull out on the bottom of the wheel while pushing in on the top.
4. While holding it in position, re-tighten the bolts.
You're done.
Some cars with strut type front suspensions are slotted here, and are designed to have their camber adjusted this way. However, the slop in the Maxima's bolt holes will still provide a limited amount of adjustment. Hopefully it will be enough.
Anyone have personal experience doing this on a Maxima?
Good Luck!
pears
Sep 18, 2015 05:25 AM
Violator
Sep 9, 2015 10:14 AM
