UGH - Sprint Spring/Suspension Help
Old Dec 10, 2002 | 07:07 AM
dtholmanmax's Avatar
All right
Here's the deal. I parked my car this morning and looked at it as I was setting the alarm and thought - Damn, the left rear looks really low, which, with Sprints is not usually the case. Then I walked around to the other side and noticed that the right rear is not nearly as low. So I'm thinking the left rear spring has fatigued already (purchased in July). If it were the shock, it wouldn't have done this, would it? HELP. Has anyone else had this problem? What springs should I go with now? God, this ****es me off.
Old Dec 10, 2002 | 07:15 AM
BOZOnPJs's Avatar
are you running stock shocks?.. maybe it's cheesed
Old Dec 10, 2002 | 07:32 AM
Dave B's Avatar
Not DAVEB the parts guy
Shocks and struts don't support any weight what so ever. They're dampers for the springs.
Park on a perfectly flat surface, make sure you have no offset weight in the trunk, and take some measurements. If the measurements are off by over ~1/4" on either side, then the spring has probably failed.
Dave
Old Dec 10, 2002 | 07:34 AM
mzmtg's Avatar
Minister of Silly Walks
Sprints suck.
Old Dec 10, 2002 | 08:07 AM
Apparently they do suck. I am on a fairly level surface right now and like I said, it acually looks good on that side. Unfortunately, it doesn't look good on the other side. I forgot to mention that I have KYB AGXs, so I don't think one of those could have already failed. Suggestions on what springs to buy next? I hate that I end up buying the same upgrades more than once.
How long can I drive on this busted spring before it blows the shock? Also, what spring do you guys suggest for a good drop? Intrax or Progress are looking pretty good to me now.
Old Dec 10, 2002 | 09:01 AM
Lime's Avatar
Originally posted by mzmtg
Sprints suck.
wisely said...from experience...muaha.
H&R's and B&G's have both been super to me.
Old Dec 10, 2002 | 09:24 AM
turbomax97's Avatar
I couldn't fix your brakes, so I made your horn louder
Wazzup Dave, Trent had the same problem, his drop was like 1/2 inch lower than mine, he got his used, mine were new....
Your springs are under warrenty, you may be out shipping though, why don't you try that?
Old Dec 10, 2002 | 10:45 AM
BC_95GLE's Avatar
Dont worry about it i had the same problem with my sprints also i went to go cut a coil off and noticed fckin dumba$$ me installed one correct and the other one backwards. This might not be your problem but that was the reason one of mine was lower than the other. Brian
HEY! mztmg Lime lay off the Sprints.
Old Dec 10, 2002 | 10:46 AM
MaximaRider's Avatar
i love my sprints so
Old Dec 10, 2002 | 10:55 AM
outkastist's Avatar
Ive been very pleased with my Progress/KYB AGX setup.
Old Dec 10, 2002 | 02:36 PM
mitch33x's Avatar
me too
Old Dec 10, 2002 | 03:05 PM
I knew I should have gone with someone who was more reputable than sprint. I just wanted LOW. Joffe, I could care less about these springs now - I just want to save the shocks at this point.
Old Dec 10, 2002 | 03:54 PM
turbomax97's Avatar
youre struts should be fine.... seems like your springs just lost their tension....
Old Dec 13, 2002 | 08:32 AM
tzmanles's Avatar
same
I just noticed that also, being a lot lower in the back. I new can just about fit 2 fingers in the wheelwell. However, I have the Eibach/Tokiko blue's setup. If I push down on the trunk, it dips down and back up once. But if I drive, it seems a lot bumpier...someone told me that the setup with adjust with the car over time and get lower. Is this true?
Old Dec 13, 2002 | 08:43 AM
NotNew!!NewSN!!'s Avatar
u check to see if you mounted the rear shocks correctly? A simple mistake sometimes, which i dont know how to phrase it right, is that you didnt put the tophat in and its only riding on the spring and not the shock. some clean up this phrase a little better please
Old Dec 13, 2002 | 08:54 AM
turbomax97's Avatar
well that would have nothing to do with the height.. the height is still solely controlled by the springs, not the strut... What's the deal Dave?
doctorpullit
Dec 12, 2015 09:39 AM
Chebosto
Feb 19, 2001 05:00 PM
ericdwong
Jan 11, 2001 10:15 PM
AznStevie
Dec 18, 2000 08:07 AM
Slickismax
Dec 5, 2000 06:46 PM
