Starter Motor Fun!
Old Dec 10, 2002 | 08:37 PM
BC_95GLE's Avatar
Starter Motor Fun!
My starter motor is givin me some ****. The damn car is stuck at my buddies house and it wont start i guess my mechanic said i need to have the connections cleaned. Not the electrical connections but the inside of the starter cleaned. I was like ok i took the starter out and low and behold it's cracked?!?! the physical device outside it got a huge crack in it. I did a little test with jumper cables and a battery and it will spin but it wont go back in. Which means a connection is bad, i think friggen car, there goes a couple hundered more bucks i dont have. Just venting it's been a long night i'm just glad the starter was easy to take out. Brian
Old Dec 10, 2002 | 11:06 PM
88MaximaSE's Avatar
Re: Starter Motor Fun!
i got a starter at a junkyard for 35 bucks and it looked brand new, u can goto the stealer and pay 300 if you want.
Old Dec 10, 2002 | 11:59 PM
KWheelzSB's Avatar
Buy through AutoZone - specify the 10-tooth, not the OEM design 8-tooth.
$115 in S. CA
Old Dec 11, 2002 | 05:45 AM
BC_95GLE's Avatar
$115 in S. CA
The 10 tooth starter? what is the benifit of that one versus the 8 tooth? Is it cheaper. THanks Brian
Old Dec 11, 2002 | 08:07 AM
TonyGotSkilz's Avatar
I bought a started from someone off the org cause i thought i was having starter trouble. After install i had the exact same problems and i realized that the tumblers in the steering column are making a bad connection or something. When it gets hot resistance in electrodes goes up making them not work as well. So when its hot it takes forever (SEVERAL) turns of the key before my starter gets a signal to start. All that said now i have 2 perfectly fine starters and i'm pretty sure my car only needs one . I'll sell my old one (which has about 35K miles on it and is in perfect condition) for 60 bucks shipped and if for whatever reason your not satisfied i'll refund your money if you ship it back. Either PM me or e-mail me (tonygotskilz@aol.com).
Old Dec 11, 2002 | 10:07 AM
KWheelzSB's Avatar
http://forums.maxima.org/showthread....=starter+motor
AaronL
Aug 8, 2020 10:31 AM
D Mason
Jun 21, 2016 04:43 AM
Unclejunebug
Apr 2, 2016 05:42 AM
knight_yyz
Nov 1, 2015 01:34 PM
maxima297
Sep 30, 2015 03:32 PM
