ECU question
Old Dec 11, 2002 | 09:58 PM
rich1223's Avatar
ECU question
I had the by ECU repaced on my 99 Max SE 5 speed by nissan about a month ago(luckily still under warranty)but ever since then the car feels like it has less power and is using more gas than with the old ECU is this possible?Or is it possible those great nissan techs installed a auto ECU?I should also mention my Max is a cali spec but i don't think that should matter.Thanx for any help!
Old Dec 12, 2002 | 12:58 AM
Nismo's Avatar
a Check engine light would have popped up if it was an auto ecu. I suggest to check the codes and see of you have a Knock sensor problem or any other problems. A Knock sensor will not cause teh check engine light to appear so its best to pull the codes out of the ecu.
Old Dec 12, 2002 | 08:58 PM
rich1223's Avatar
Thanks for the info Iam bringing the car back to Nissan to see if they get any codes off the ECU or to see if there is another problem.
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
junito1
Sep 23, 2015 12:14 PM
Socalstillen
Sep 20, 2015 11:46 PM
QueensMAX
Sep 15, 2015 04:14 AM
