Gas smell when i turn on heater. HELP
Old Dec 13, 2002 | 05:42 PM
yema0003's Avatar
When i turn on my heater, gas fumes come into my car, only way to stop it is to circulate the interior air.
It's ruin a perfectly good 95'
Does any body have any suggestions on what it could be ?
I figure i should have an idea before i take it to the shop.
Thx
Old Dec 13, 2002 | 08:25 PM
pmg's Avatar
pmg
Re: Gas smell when i turn on heater. HELP
I've got a similar problem I'm going to look at tomorrow. Open the hood, find the fuel filter. Trace the rubber fuel lines around with a flashlight and look for a leak. Tighten screws or replace hoses if necessary. The cold weather loosens the rubber hoses and makes leaks more common.
Old Dec 13, 2002 | 10:44 PM
nismoflo's Avatar
same problem here. I have no clue what it is. If anyone finds out what the problem is can you please post it here. Thanks in advance
-nismoflo
Old Jan 22, 2003 | 03:13 PM
nismoluvr's Avatar
I have this smell today. It is -11 here today and I left my car running for like 20 minutes to warm it up, and when I went out it smelt bad like gas inside. I turned off the heater and it went away. Anybody got a fix yet?!?
Jason
Old Jan 22, 2003 | 03:26 PM
JMAX95's Avatar
I had replaced the top hose coming out of the fuel filter just recently. One night driving, I noticed a nasty gas smell. I went home to investigate. It turns out to be a pin-sized hole in the top hose. It was squirting out gas when the car is on. I went to autozone and bought a 9" hose to replace. The original was maybe 7". I figure a longer hose would be better for fuel filter change later on. Instead of yanking on the top hose, I might as well cut it.
shilov
Feb 19, 2024 09:40 PM
Mar 12, 2020 12:06 AM
captchaos
Mar 15, 2016 12:18 PM
Smackasmith
Feb 1, 2016 12:40 AM
LtLeary
Sep 14, 2015 12:33 PM
