PCV - wrong one for my 99 SE !!
Old Dec 14, 2002 | 10:24 AM
ezemax99se's Avatar
I bought a Purolator PV1058 valve for my 99 SE-Limited. It is the wrong one. That is the one that the Purolator Book said at Pep Boys but the valve was clearly the wrong one. It was longer than the OEM and the end that goes into the crankcase was not the same style.
As many of you already know, changing this valve is not easy in the first place. I went to the trouble of removing the FSTB and then get the valve all the way out and I don't have the right one to replace it with. Oh well. I will get an OEM one and then replace it.
I hope this post will prevent some of you from dealing with this situation. Take care all and thanks for all the advice I have received from the org. in the past.
Old Dec 14, 2002 | 11:07 AM
I30tMikeD's Avatar
Re: PCV - wrong one for my 99 SE !!
Did the same thing. Bought one from NAPA. It was basically the same general shape, but just did not fit in the whole like the OE one. Took it back and went to a dealership. Dealer charged me $13!!
Old Dec 14, 2002 | 11:57 AM
ezemax99se's Avatar
Re: Re: PCV - wrong one for my 99 SE !!
I know the dealership is way overpriced but $13. That is highway robbery. That will be one of only things I ever buy from them except the OEM oil filters. Which I replaced today when I changed my Mobil 1 sythetic 5W 30. I priced the OEM brake pads while I was at the Nissan dealership too. $75 for just the front pads. They are such a rip-off. I will get the Raybestos QS pads I guess.
Thanks for the input.
Old Dec 14, 2002 | 12:03 PM
Sin's Avatar
Sin
$13?!?! Man, my PCV was $10.95 Canadian from the dealership.
I think the oil filters are ridiculously priced. They are like $10 Canadian each! The only way I ever buy them is in dozens with a discount.
Oh Yah! Why are you guys complaining about it being difficult? I did mine in literally 1 minute. All I did was move that valve looking thing out of it's mount to make more space, then used a screwdriver to loosen it, pulled it off, pushed in the new one.
Old Dec 14, 2002 | 12:06 PM
buss95max's Avatar
same thing happen to me. i got the end of my rachet and tapped it in there though. it wasnt hard at all, i kinda force-fit it for now and i havent had any problems.
ezemax99se's Avatar
The oil filters are only $8 and some change here so I don't mind that. But $75 for just front brake pads is just outrageous. They won't get it from me.
Old Dec 14, 2002 | 12:08 PM
ezemax99se's Avatar
I could have done the same thing but the problem was that the hose end of the valve was longer than the OEM too. This would have made it impossible to get the hose back onto the fitting at the other end without cutting it. I would rather wait and just get the OEM.
Old Dec 14, 2002 | 12:10 PM
buss95max's Avatar
i just cut the hose and made to length of the PCV. i dont have a brace holding it onto the PCV, the hose is long enough to where it pushes the PCV down. a snug fit i guess you can say.
Forge277
Jun 13, 2016 09:26 PM
bigfrank
Oct 1, 2015 12:51 PM
bumpypickle
Sep 20, 2015 08:22 AM
pears
Sep 18, 2015 05:25 AM
