Changing Factory Fog Light Bulbs
Hey guys and gals, I know this is probably a very basic question, but I need some help. I have a 96 Maxima SE (recently purchased), and I want to replace the factory fog light bulbs with Piaa H3's. I'm having a real problem finding information on how to remove the housing (I've searched through forums, used search engines, etc for HOURS!!) The fog light housing seems to be in two parts, but when i try to pry the small lens away from the larger one, (don't wanna break it!) it seems like they are both attached by screws??? This cannot be. Someone please help and excuse the basic question.
Thanks in advance,
BigD
Thanks in advance,
BigD
You are right. First you have totake a flat head screw driver and pry at the bottom of the small piece closest to the middle of the bumper. When that peice comes off then you will see two screws. The big on will have to come out. When you take that screw out you just slide the light towards the middle off the car and it should come off. Then you unscrew the black plastic cap and there is your fog light. Undo the little metal clamp that holds the light in and there is your fog light. Hop this helps sorry about it being long.
BigD
vingodine
45
05-21-2016 12:46 PM
Viralkill
08-17-2015 10:54 AM
MikesChevelle
08-06-2015 11:36 AM
