Making An Intake
Old Dec 18, 2002 | 04:57 PM
sebaxx's Avatar
Making An Intake
AS I TOLD YOU GUYS A FEW HOURS, IM MAKIN MY OWN INTAKE...HERES THE QUESTION...I PUT THE 3 ADAPTER FOR THE HOSE AND IF YOU LOOK INSIDE THE MIDPIPE YOU SEE A LITTLE PART OF THE ADAPTERS...I DONT KNOW IF THAT MAKE SOMETHING BAD(LIKE TURBULANCE) THE THE AIR FLOW IS PASSING BY OR IS OK...AND DOESNT MATTER IF THE ADAPTERS FOR THE HOSE HAS A LITTLE PART INSIDE
LET ME KNOW YOUR OPINION.
Old Dec 18, 2002 | 05:24 PM
MDubya
Re: Making An Intake
>>>CAPS OFF CAPS OFF. I cant fit it all on one page.
Old Dec 18, 2002 | 05:44 PM
korupter's Avatar
no, it won't make a difference. If you're still skeptical, just take a look at how much resistance in the stock intake and compare it to your new one. Oh yea, if money isn't a problem, you should just buy a midpipe. It would save time and stress.
Old Dec 18, 2002 | 06:51 PM
DJSmitty's Avatar
I got double-sided brass barb connectors, and cut them so very little extended into the actual pipe. Mine still stick in a little, and I've had no problems with it. I have some pics on my site, but not of the inside.
-Smitty
Old Dec 18, 2002 | 09:46 PM
I30tMikeD's Avatar
I would not sweat it. Mine stick in like an 1/8" or a little more. An intake is not a real big HP{ mod in the first place.
Old Dec 18, 2002 | 10:25 PM
Skoodaddy's Avatar
Not sure about the I30...but my Max got incredible gains off of my custom intake, it cost me $15 from Lowe's plumbing section and $20 for filter and adapter from ebay. Click on my website..go to pg 2 I think, There are some pics and some instructions.
Old Dec 18, 2002 | 10:30 PM
I30tMikeD's Avatar
Yhea my I30t 5-speed is a totally different car
You got no more than 7 hp from your intake. Incredible gains??
Old Jan 19, 2003 | 08:47 PM
ivelweyz
Bringin' back from the dead. The cone filter you got from ebay, is it rechargable like the k&n, just spray it with some oil, dry and replace, or is that only a k&n thing???
Old Jan 19, 2003 | 08:59 PM
Skoodaddy's Avatar
It's a Matrix, get a new one when it's dirty, it's $20 w/ adapter. I'm sure you could clean it,
Old Jan 20, 2003 | 04:29 PM
ivelweyz
Can't find it anywhere!!!
Old Jan 20, 2003 | 04:35 PM
ivelweyz
Old Jan 20, 2003 | 05:06 PM
Street Reeper's Avatar
Handsome
No it probably won't, but if your still unsure just unscrew them a little. If you feel the need you could lock them in with your choice of sealant.
Old Jan 20, 2003 | 05:28 PM
blakkrob's Avatar
WHere do you guys find the 3 inch I.D. tubing. I haven't been able to find any. 2 1/2 is the largest I can find
Old Jan 20, 2003 | 06:03 PM
I30tMikeD's Avatar
AutoZone, in the exhaust section.
Old Jan 20, 2003 | 06:17 PM
skeetsmax's Avatar
must be autozone..i work at advance auto and we dont have it...
Old Jan 20, 2003 | 07:56 PM
Skoodaddy's Avatar
If you are talking about replacing the "box" that has the 3 Vacuum Hoses coming off of it...
Lowe's - Plumbing Section - 3" Fernco Rubber Coupling
Page 2 of my Homepage for hose adapters
Old Jan 20, 2003 | 11:12 PM
I30tMikeD's Avatar
he is wanting to make the metal piping. Not the rubber.
Old Jan 21, 2003 | 07:16 AM
ivelweyz
MURRAY'S or however you write it, it's $9.99 though...
Old Jan 24, 2003 | 06:50 AM
chrisco
I just installed the homemade cone intake on my 97se and I had to screw the larger adapter at least a 1/4" past the I.D. since the adapter I used had a tapered thread and my hole came out a little bigger than I planned. So far it seems to work well but I may fix it with a new adapter and sealant later on.
Off the subject did you use the small breather filter on the engine block? I used the original hose and put the breather at the end to keep it away from the heat a bit. Also I kept the scoop intact but removed the bottom half of the original air box. The rectangular opening now dumps some air out right where the cone is. IU don't know if this helps at all though. All in all a fun project except for the 4 stores before I found the 3" ID pipe. Have fun
Old Jan 24, 2003 | 07:43 AM
96BLUMAX's Avatar
After trying to make countless home intakes, my advice would be just buy a manufactured one because in the end it will cost less.
Old Jan 24, 2003 | 07:46 AM
I30tMikeD's Avatar
After making two different homemade intakes, my advice is to do it. It will cost less and it's the same damn thing.
Old Jan 24, 2003 | 04:12 PM
Skoodaddy's Avatar
WORD!
Old Jan 25, 2003 | 06:51 AM
Handsome
Old Jan 25, 2003 | 07:46 AM
I30tMikeD's Avatar
Ohh, I forgot to add that making it is half the fun!!!!
Old Jan 25, 2003 | 08:16 AM
Handsome
Having an intake just the way and color you want it, getting hp at a much lower cost, and impressing everyone with your ability to make a proffesional looking intake, is the other half
Old Jan 25, 2003 | 11:01 AM
JMAXIMA's Avatar
got my midpipe from a local muffler shop for ~$15... the guy cut and flared it to fit the couplings and gave me some new hose clamps. worth the extra few $$ to me. plus he offered to make a b pipe for me for $80 w/ or w/o resonator... my next project.
Old Jan 25, 2003 | 11:53 AM
fierostetz's Avatar
what about using clear acrylic tubing (the kinda blue tinted stuff) it would be clear (cool, no?) and UV reactive... any interest in this? i posess all the tools to make damn near anything for a car, but won't be experimenting much until i get my tranny to stop acting up..
Old Jan 25, 2003 | 11:57 AM
fierostetz's Avatar
like this
http://members.***.net/maximastetz/uvreact.jpg
220k+ A32
Sep 11, 2015 02:18 AM
Maxboy23
Sep 9, 2015 10:37 AM
A32goldylocks
Sep 2, 2015 06:39 AM
