How to improve gas mileage?
Old Dec 19, 2002 | 09:26 AM
Grey00lustre's Avatar
i heard people doing maintenance like the pcv valve, 02 sensor, ngk plugs, or knock sensor...which one should I do since my car is a 98 with close to 50k? also where is the cheapest place to buy parts for them?
Old Dec 19, 2002 | 10:41 AM
njmaxseltd's Avatar
At 60K your due for a tune up.
Plugs
Air and fuel filters
Clean or replace your PCV valve
Clean your throttle body
Inspect belts, hoses, coolant, brakes, ect.
Transmission fluid change
Power steering fluid change
Change oil and filter if needed too
The o2 and knock sensors are not maintenance items. If they fail, you replace them.
You can get the parts at your local Nissan dealer or try Courtesy Nissan on line. They have tune up kits for the Maxima at very good prices.
Old Dec 19, 2002 | 12:13 PM
FLO_BOY's Avatar
you could drive slower
Old Dec 19, 2002 | 12:41 PM
nadir_s's Avatar
vicodin ... gift of life
be like me, shift at 3k
Old Dec 19, 2002 | 03:17 PM
95emeraldgxe's Avatar
Re: How to improve gas mileage?
what is your gas mileage to start with???? exhaust and intake mods help your fuel economy as well
Old Dec 19, 2002 | 05:17 PM
happyricefob's Avatar
V^___^V
- at local drive 45 (saves the most gas)
- on high way drive 75 (not 2 fast nor slow, fast enough to get to places unless ur on road trip)
- shifts when u hit 3000rpm
- get 87 octane @ costco or safeway
Old Dec 19, 2002 | 08:56 PM
Greg's2kGLE's Avatar
Originally posted by happyricefob
[B
- get 87 octane @ costco or safeway [/B]
Costco sells gas?
Old Dec 19, 2002 | 10:12 PM
Sean97SE's Avatar
yah! it's really cheap too! i love costco
Old Dec 20, 2002 | 05:05 AM
mrmaxima97's Avatar
Old Dec 20, 2002 | 07:09 AM
98maxsel's Avatar
isn't a intake supposed to get you better mileage?
Old Dec 20, 2002 | 07:46 AM
BLACKICE99's Avatar
DO NOT i repeat DO NOT DO THIS..........
Old Dec 20, 2002 | 10:08 AM
Eric L.'s Avatar
I love everything else Costco sells, but after constant hesitation with Costco 91 octane, I will never buy it again. I am also super wary of these crappy Nissan knock sensors which go bad all the time. No point killing another sensor by running Costco super.
Old Dec 20, 2002 | 10:52 AM
FLO_BOY's Avatar
I wouldn't do this...
on a FULL tank of gas, you're looking at MAYBE $3 more for premium.
So, if you buy a full tank a week, that's $150 more per year.
Your car is meant for PREMIUM...running crappy gas will retard timing, meaning
less horsepower, and basically a poorer running car.
you're extra $3 could save you MANY DOLLARS down the road...especially
when you tell a perspective buyer "I always used premium", and because your
repair bills will be lower...
my $0.02,
FLO_BOY
Old Dec 20, 2002 | 11:09 AM
(_8*(l)Homer's Avatar
What??
Use 87 octane if you want to keep replacing knock sensors and other various parts due to using this gas. Or, if you want to keep your max for a long time, use the recomended 91 octane or higher.
My 2ยข
Old Dec 20, 2002 | 11:17 AM
white95max's Avatar
Do not use 87 octane gasoline in a Maxima. Maximas require at least mid grade gas, if not premium. 87 octane would not increase your gas mileage anyway. The one time I put 89 octane in instead of premium 93, I had a knock sensor code come up.
mclasser
22
Nov 12, 2020 01:58 PM
maxinout93
Oct 31, 2015 02:04 AM
Sep 27, 2015 08:37 AM
