1999 Gauge cluster bulb #..need confirmation
Old Dec 23, 2002 | 12:05 AM
JPMax's Avatar
What's next!?..
Hey guys,
I know the 99 gauge cluster bulbs are not 194s. I seem to remember someone saying they were 74s.
Can anyone confirm this?
Also, where can I find some blue ones?? I've searched through Google.com with "74 bulbs" and got next to nothing.
Old Apr 1, 2003 | 05:31 AM
Odie96's Avatar
Does anyone know the p# for a 96?
Old Apr 1, 2003 | 07:18 AM
clee130's Avatar
96 is #194
99 is not #194 ... not sure what they are since I never had a 99.
Old Apr 1, 2003 | 07:47 AM
fearthegecko's Avatar
Most Perverted Member of the SE-L Club
Re: 1999 Gauge cluster bulb #..need confirmation
Originally posted by JPMax
Hey guys,
i wish i could tell you, but even after telling my year, make and model, trim level, and exactly what bulb i wanted, the parts manager at my local nissan dealership still couldn't figure out what bulb i needed. His helpful advice was to "rip apart the gauge cluster, and pull out the bulb that was burnt out, put the cluster back together, bring the bulb in so he could match it up, then rip the gauge apart again to get the bulb in there (and pray he gave me the right one)"
Fock em.
Old Apr 1, 2003 | 10:02 AM
Speebs's Avatar
I aim to misbehave.
Re: Re: 1999 Gauge cluster bulb #..need confirmation
Fock em.
I am almost 100% certain that the last time I took apart my 99 cluster, I noticed that the bulbs that illuminate the gauges/needles are the exact same as the bulbs used for the CEL, Battery, Gas light, etc. I just called the local dealer and he insists that, according to the Nissan diagram, there are FIVE different types of bulbs behind a 99 cluster. I don't believe him. I lied and said that I needed a new fuel "empty" bulb, and he said "yep, I have that one in stock," but he couldn't tell me what bulb type/size it was. Right. I've taken apart the cluster numerous times and all of the bulbs are interchangeable. Even if he was talking about one of the earlier 4th gen. clusters, there are only 2 types (I have a 95/96 cluster sitting right here with me): 194 and these little ones, whatever they are.
Anyway... when I have time, I can try switching one of the gauge bulbs in my 99 with the fuel/CEL light from the 95 cluster and see if that works (I'm betting it will). If it does, then at least we'll be headed in the right direction (someone will have to call another dealer and find out what type of bulbs are used in all years for the CEL).
fearthegecko, if this works I can mail you a bulb since I have like 10 in this old cluster. PM me or something.
Old Apr 1, 2003 | 10:12 AM
dudevolley's Avatar
ok...you can't search b/c the function is down, but the 99's do not use 194 bulbs. they are smaller, and i've tried to do blue bulbs but cannot even find regular clear bulbs. it's a much smaller version of the 194 bulb. some people have painted them blue with a sharpie marker, but i would not waste your time. hope this helps.
Old Apr 1, 2003 | 04:23 PM
JPMax's Avatar
What's next!?..
Wow, this one got pulled from the depths of obscurity. I had forgotten that I posted this..
Anyway, yep.. 98-99's use some weird size bulb that apparently no aftermarket manufacturer sells. You can only get them at Nissan in clear.
74's will work, but they are smaller and not as bright.
BTW, the blue sharpie idea doesn't work. It eventually burns off and you're back to clear again.
Old Apr 2, 2003 | 09:43 AM
Re: Re: Re: 1999 Gauge cluster bulb #..need confirmation
thanks, i'll see what happens. Dealers suck.
Old Apr 2, 2003 | 11:03 AM
xHypex's Avatar
Re: Re: Re: Re: 1999 Gauge cluster bulb #..need confirmation
Dealers are there so they can give you their part #. If they just told you info about the part (be it a bulb, screw, etc.) you would go elsewhere I have never figured out why the FSM doesnt cross reference part #s though.
-hype
Old Apr 2, 2003 | 11:26 AM
Speebs's Avatar
I aim to misbehave.
Re: Re: Re: Re: Re: 1999 Gauge cluster bulb #..need confirmation
-hype
Yeah, I know, but it's annoying that they are so self-serving. Maybe I wouldn't have a problem buying things from them if they didn't charge an arm and a leg for something that is only worth a finger.
Old Apr 2, 2003 | 04:36 PM
ballinontwins's Avatar
To answer your question about the bulb cluster. Bulb code is 24. They are the same as the gas, high beem, etc. The only colors i've other then white is yellow. I've tried looking for them in different colors, but you will have better luck putting a condom on the bulbs.
Old Apr 3, 2003 | 12:14 AM
Re: Re: Re: Re: Re: Re: 1999 Gauge cluster bulb #..need confirmation
litch
123
Jan 4, 2024 07:01 PM
Miket2006
Mar 1, 2021 03:55 AM
doctorpullit
Mar 29, 2016 11:08 AM
mpbclutch33
Dec 26, 2015 11:11 AM
Noela
Sep 26, 2015 08:22 AM
