odometer problems
Old Jan 5, 2003 | 03:09 PM
mrbill's Avatar
odometer problems
Posted this a couple of times before. Thought I would try one last time: Have a 96 Max, 5sp. Analog odometer and tripometer just stopped working for period of several days (figure we drove over 200 miles). Tried resetting the tripometer several times, no luck. As of a few days ago both gauges are now mysteriously working again!!! Has this happened to anyone else? Any ideas as to the cause (and fix should it happen again)? Thanks.
Old Jan 5, 2003 | 05:02 PM
Maxpower96's Avatar
Same thing here - 96 gle
but this happened a bit before my starter died. Chenged ny starter and ever since, both meters have been working. Don`t know if it is much help, but check the wires near the starter. they are located under your airbox/ tb.
Good luck friend.
Old Jan 5, 2003 | 06:05 PM
Ramius83
It is your vehicle speed sensor. I had the same symptoms as you, except my speedo also would not work. I checked the harness going to the vehicle speed sensor and it was secure and not loose. So, I got one from Ericdwong for $10.00, popped it in, and everything works now.
Old Jan 21, 2003 | 06:47 PM
mrbill's Avatar
Thanks, but have been unable to find a part called a "speed sensor" and I don't know who ericdwong is. Any ideas where I can find this part and/or get some info on what's involved with installing it?
user 11122324
42
Jul 18, 2022 03:35 PM
Noela
Sep 26, 2015 08:22 AM
homewrecker
Sep 24, 2015 07:01 PM
