A'Pexi SAFC II???
Originally posted by mzmtg
Unless you are boosted, either one would be a waste of $$.
it is a valuable monitoring device, NA or forced...
Originally posted by Jer
Well, what new features does it have? I don't read japanese!
The S-AFC II features a user-definable, 12-point ( 8 pt for SAFC), adjustable fuel curve that can be set in 200 RPM increments( 500 RPM increments for SAFC
Yeah, but aside from that (you can read that part in the table on the japanese site)?
I'm about to pick up the S-AFC.. if the S-AFC II has something noticeably niftier, I'll get that instead..
Originally posted by MAXIN
for starters....
for starters....
No it is not...you would spend just as much money on gauges alone and not be able to ever make any changes ... best advice is, you can get a horse to do a pony's job, but you cannot get the pony to do a horse's job
It's useful, but by no means is it a replacement for the all gauges... well, who knows what it is in this case - the S-AFC is good, to a point - egt or af ratio, boost, fp would still be useful.
Dunno if the s-afc II does anything else or what else it taps into, I do not read japanese (and I guess nobody else here does either
Originally posted by Romeo
so would this be a suitable device in place of obtaining actual gauges in the case that someone is turboed/sc/nos?
My S-AFC read throttle position in percentage and analog, rpms in analog and numerically, afr under ALL conditions, and any applied corrections, can do peak hold and replay for diagnosis/tuning ...nothing different I am guessing from the new one but we'll see soon enough...no replacement for Boost Gauge, Oil/Fuel Pressure or EGT gauges on this but is good for overall monitoring of many things performance oriented NA drivers would be concerned with...
You seem to have problems understanding.
All that link indicates is the 200rpm / extra points where you can adjust the mixture.
Please grace us with your higher intelligence and post more information, otherwise you may sit on it and rotate
Originally posted by speedemn
The e-bay link that I posted with sufficient info. on this product does not look like Japanese to me. I can understand it and I thought that the ebay auction was in english. Correct me if I'm wrong.
I was just goofing around... I didn't look at the website.
The auction however did mention more than just 200RPM (vs 500RPM) increments. In any case, the SAFC will probably drop in price big time when the SAFC II comes to the US. Unless you have the cash I don't think the SAFC II is anything special, especially for an NA car... the SAFC would be sufficient.
I'm hoping it does other cool stuff, but the company site has the info in .jpg format and won't go through a translator
I should get a japanese girlfriend instead of Palmela!
Doesn't everyone speak Japanese?
Ok, looks like I found out :
http://www.takakaira.com/asp/template.asp?id=815&cat=2
It has a knock sensor display w0000000000!
MaxxTuningUSA
Apr 24, 2003 02:24 PM
Str8Maxin
Jan 15, 2002 11:16 AM
