Power Window Noise
Old Jan 9, 2003 | 11:05 AM
JonnyCum Lately's Avatar
Power Window Noise
I drive a 97 SE. My driver side window recently started making a slight grinding/rubbing noise when its about 3 to 4 inches from being completely lowered. No noise when it goes back up. Is this the result of accumulated dirt? If so, any easy remedies to clean the tracks? All the other windows are fine. The glass is not tinted.
Old Jan 9, 2003 | 11:09 AM
njmaxseltd's Avatar
Nice member name, have you?
It's probably dirt stuck down in the track. I think I recall somebody posting some kind of window lube for the tracks on here.
Use the search function and match key words like window noise, or window track.
Good luck and welcome aboard the org.
Old Jan 9, 2003 | 11:12 AM
Sprint's Avatar
not exactly ... but kinda
http://www.turbomaxima.com/modules.p...iewlink&cid=28
Old Jan 9, 2003 | 11:14 AM
Thanks for the advice! This is a great board to join. In the past day I learned about how to change my fuel filter and ATF. I have 79K and haven't done either of these maintenance requirements.
Old Jan 9, 2003 | 11:51 AM
GreenSE's Avatar
I've used a spray lubricant made by Pyroil in a red and black can. Got it from pepboys for around $4. Just spray on the tracks and repeat every 2 - 3 months.
Old Jan 9, 2003 | 12:00 PM
Thanks GreenSE. You're right. I searched the forum and everybody said to spray silicone lube into the corner of the door near the driver side window.
pears
Sep 18, 2015 05:25 AM
