Battery died, need replacement...Suggestions :)
Hey guys,
I noticed my car won't start when it's cold out, i really have to have my foot on the pedal to start it, therefore i am in need of a new battery. now i do have a fairly advanced stereo system running off it, however I would need the best battery suited for my cold climate here in Canada. I was looking at an optima yellow top but i read the red top was best for starting. Maybe you guys have other suggestions, thanks
Re: Battery died, need replacement...Suggestions :)
Originally posted by OpTikOl
Hey guys,
Hey guys,
im running an optima yellow top, and it does the job pretty well.
if you have a stereo system, spend the extra bit and go with the yellow top, it has the deep cycling crap, which is apparantly good for aftermarket electronics.
Re: Re: Battery died, need replacement...Suggestions :)
Originally posted by Dev
hey, im in canada as well, toronto to be specific...
deep cycle batts are good if you constantly run your battery real low.
http://www.odysseybatteries.com/ has some GREAT batteries for all uses, including deep cycle. it is rumored that they make batteries for stinger.
Hey guys,
Hey guys,
the gas to start the car, sounds like your engine has problems, not
the battery. Does it have trouble cranking the engine over?
Hey guys,
Hey guys,
I got a die hard in mine, seems to do the trick, I'm not sure about all those special batteries, I never used em b4, seems the die hard gold would be good for the cold weather.
![](https://maxima.org/forums/images/smilies/support.gif)
Originally posted by 975spEEd
How do you figure you need a new battery because you have to press
Re: Re: Re: Battery died, need replacement...Suggestions :)
I just cashed in on this deal....I don't have any heavy load on my electrical system other than some real cold winter starts, or when the car sits for a week or two.
Originally posted by Curt Deiner
Die Hard Gold here. $80 and 3 year free replacement then 100 months pro rated.
Originally posted by 95CustomMaxima
I dont think that the battery is your problem...a battery would only be needed if your car doesnt turn over...giving it gas to start has nothing to do with the battery.
-Nick
-Nick
My battery died today (7-year old OEM battery). It tried to crank and then it was done. Starting had been hard ever since the temps dropped. I went to Sears and got a Die Hard "Silver" ($69, 630 cold cranking amps) and it fits the factory battery sleeve nicely. I hate the looks of all these colored batteries. I want everything to look factory. As for battery performance, the car starts instantly.
Dave
Dave
The Die Hard Gold did not fit very nicely in the battery sleeve.
When it gets warmer out, I need to take a utility knife to the sleeve.
Dave
Dave
Dave
Dave
I don't have any high power stereo systems (just factory Bose) so Costco's battery is working for me. I installed a new one when I bought my car in Oct 2000, and it works great for me so far. BTW, I live in Vancouver, B.C. ![Smilie](https://maxima.org/forums/images/smilies/smile.gif)
You may want to look into other possible causes, like fuel filter, dirty TB...
Not your battery
Hey,
I have the same problem too. My car won't start unless I use the gas pedal in cold weather after sitting overnight. I had my battery tested and it's fine. One of my friends mentioned to me to have my throttle body clean. I had it done and still have the same problem. I think the problem is the spark plugs. I going to have a tune up and change everything from spark plugs, fuel filter, pcv valve, air filter, etc. Give that a try. I will let you know how my car turn out after the tune up.
atb0423
atb0423
06-06-2017 02:01 PM
bigfrank
10-01-2015 12:51 PM
maxima297
09-30-2015 03:32 PM
