Draining power...
Old Jan 9, 2003 | 10:48 PM
Lost_N_a_97Max's Avatar
Draining power...
My new old 97 Maxima GLE keeps draining its' battery. I just got it 2 weeks ago. Anyone have a problem like this or know what the cause could be?
When the car's off and the stereo's on (BOSE if it helps) and you attempt to do something such as drop all four windows at once or just slide the moonroof back the stereo will either stop playing or cut all the bass and fade to the front right speaker. The same thing also happens when driving while braking.
While sitting in the car listening to the radio with nothing else on for less than 10 minutes the battery would be dead.
I know it's possible to chill in the car without it running and listening to music. Also, the heated seats were off.
I learned of the alternator recall earlier this week and went to Nissan, who installed the new one in 2 hours the next day.
(The battery still died)
Bought a new battery..
Car hasn't died yet, but the lights still flicker and the radio cuts off.
any help?
---Lost
Old Jan 9, 2003 | 11:00 PM
NyCzBuBBa's Avatar
Re: Draining power...
any help?
---Lost
I have a similar problem. Like if I step on the brakes my headlights will flicker if i have hazards on and my interior light on the interior light will flicker and my radio shuts off sometimes. My alternator belt squeels and it doesnt charge I think I might need a new battery and change the belt any suggestions?
Old Jan 9, 2003 | 11:44 PM
NiNe7-Gxe's Avatar
Hey man i got the same problem last time i forgot to turn off my lights and i just went to order me a meal at KFC got back within 10 mins my **** was dead, i know cars can last longer than that, i also cant listen to the radio without my car being on which suckssssss,
i have a nissan battery that came with the car which had JAn and 02 cut out i guess its only been a year but this happened like months after i got the car...
dunno maybe its just the crappy nissan battery
Old Jan 10, 2003 | 05:51 AM
njmaxseltd's Avatar
any help?
---Lost
Use some creative thinking here. Nissan Warranties their work. Go back to Nissan and tell them the problem just started happening after they installed the new Alternator. Make them fix it for you.
Old Jan 10, 2003 | 10:48 AM
Should that not work, I'm still looking for some possible reasons.
Old Jan 17, 2003 | 05:42 PM
BurgandyMAX's Avatar
I have a 3rd generation and I am having the same problems as described. I have to keep charging my battery!! Got a new one and died right away. Was so ****ed. Cant play the radio without the car being on. The mechanic tried to fix this once and unhooked the security system, still having the problem, dont have a warranty. any suggestions?
Old Jan 27, 2003 | 11:58 PM
After going back to Nissan and having them check their alternator the tech. finds out that i have "no diode ripple found" and "system failure" displays on his gauge. The battery only registered 12.51 volts. When it should be between 13-15.
While in the process of replacing the alternator, it's found out that there is a loose wire conection and pin.
Once properly fitted, the battery registered 13.36 volts.
The hard starts have stopped and the music plays without problems so far.
Hopefully thats the end of it, to anyone having the same problem, I'd recommend having that checked out. Tis pretty simple. And was FREE for me.
---Lost
Old Jan 28, 2003 | 05:54 AM
njmaxseltd's Avatar
Translation - The tech that did the job the first time screwed up and forgot to plug something in!
Old Jan 28, 2003 | 12:01 PM
MacGyver265's Avatar
The battery only registered 12.51 amps. When it should be between 13-15.
Once properly fitted, the battery registered 13.36 amps.
---Lost
I think you mean Volts, not amps. Car batteries and electrical systems are measured in terms of Voltage. 13-15 amps would not be nearly enough to power a car and its accessories. The amp rating of the alternator should be somewhere around 70amps or so. Anyone know for sure what the alternator is rated at.
Anyway, I'm glad you got your problem fixed. I just wanted to point out that crucial error. Amps and Volts are very different things.
Old Jan 29, 2003 | 12:00 AM
Yea i did mean volts... my mistake, thanx for the correction.
Forge277
Jun 13, 2016 09:26 PM
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
foodmanry
Sep 24, 2015 12:02 PM
97_GXE
20
Sep 17, 2015 08:12 PM
markevans999
Sep 10, 2015 04:29 PM
