Intake Research
Old Jan 12, 2003 | 11:12 AM
Kolyan's Avatar
Intake Research
I posted a thread about intakes before, i also read alot of threads on this forum about JWT/Stillen Pop Chargers, Hybrids, and CAI. I personally came to conclusion that it's not worth upgrading to any of those intakes, unless you have a really specific goal (say you like the sound or you want better 1/4 runs).
Pop Chargers: you loose low-end due to the hot air from under the hood and you gain a little high-end.
CAI: you gain low-end due to cold air and you loose high-end due to extra piping.
Hybrid: i don't really understand why many people prefer this set-up. you get extra piping and you still get hot air.
For all those minimal gains and power losses you have to pay. and also i can agree with people that wrote that stock air box will collect more dust.
Correct me where i am wrong here.
Old Jan 12, 2003 | 11:17 AM
Vyrus's Avatar
READ CAREFULLY AND ENJOY!
Originally posted by Str8ridin
I perused quite a few SAE articles regarding intake temperatures and their effect on different engine applications and found an interesting standard: By using the SAE correction factor "B" for temperature's effect on horsepower, we see that the correction factor for temperature is approximately 1% per ten degrees. That is, you get a 1% increase in horsepower for each 10 degrees you lower the temperature of the incoming air into your filter.
I am certain that many of you have personally felt the difference, on a cool, perhaps damp
(there is another correction for that) morning, when your car seemed to have more power than usual, and that those of you who have been lucky to participate in track days have posted lap times in the cool of the morning you could not equal on the warmer afternoon sessions.
This finding prompted me to swing by the local Radio Shack and purchase a digital thermometer with the sensor attached to its 10-foot wire. I attached it to my door.
http://images.cardomain.com/installs...72_17_full.jpg
I then routed the wire connected to the thermometer’s display out the window, under the hood and inside the cone filter to get the exact temperature of the air entering the throttle body.
http://images.cardomain.com/installs...72_19_full.jpg
Here is what I tested:
1) Intake Temperature at IDLE (8 minutes) with Pop Charger
2) Intake Temperature at IDLE (8 minutes) with CAI (I placed sensor in drainage hole in fender where the CAI would reside)
3) Intake Temperature with Pop Charger
4) Intake Temperature with CAI (I placed sensor in drainage hole in fender where the CAI would reside)
5) Intake Temperature with OSCAI (A 2” tube connected to a scoop under the car bringing cold-air to the filter. SEE
http://images.cardomain.com/installs...72_11_full.jpg
Here are the results:
Outside Temperature: 34 degrees F
Test length: 2 Miles/Run
1) Intake Temperature at IDLE with Pop Charger: 95.8F and increasing
2) Intake Temperature at IDLE (8 minutes) with CAI (Sensor in hole in wheel well): 51.2 Steady
Temp @ 40 mph: 47.6F
Temp @ 70 mph: 44.2F
Notes: The temperatures were volatile and increased when accelerated hard or came to a brief stop. Temperatures would not reach their low until the end of the run. When stopped for more than 2 minutes, the temperature would rise quickly to between 60-65 degrees.
Temp @ 40 mph: 45.1F
Temp @ 70 mph: 39.8F
Notes: Idle temps were already low, so low temperatures were achieved quickly. The temperature did not vary and stayed relatively constant when accelerating hard or stopping. Extended periods of idle would bring the temperature up, but not significantly. I suspect using the fender well as a heat shield aided in the temperature consistency.
5)Intake Temperature with OSCAI
Temp @ 40 mph: 45.0F
Temp @ 70 mph: 40.9F
Notes: The rate of change for the temperature was dependent on the speed I was going. The temperature increased when accelerating hard or coming to a stop, but quickly returned to it’s low under steady driving. Again, as the basic pop charger set-up did, momentary stops for 2 + minutes would send the temperature up to 60-65 degrees.
Conclusion/Serendipity
I was surprised that the Pop Charger by itself, without the CAI or OSCAI set-up was able to produce almost same temperature reading as the other two at speed. I guess, from what I gathered, the CAI benefits the most by creating a ceiling for temperature not to exceed (in this case 50 degrees) whereas the other two allow the intake temps to climb at the engines heated will. This 40 degree difference can be a factor in ¼ mile times where the car must idle for extended periods of time before launching. But as the outside temperatures increase, so will the air in the wheel well, thus making the differences slight. Additionally, I am not certain what adverse affects the longer tube combined with a bend may have on the intake airflow. Perhaps the tube may heat up thus warming the cooler air.
In the end, when comparing the extremes of winter and summer weather, say 10F vs. 100F (engine temps) and using the 10degree/1% power gain correction factor equation, in the Maxima’s case:
100-10 = 90 * .10 = 9% power increase for a 190 hp car which is somewhere around a 17 horsepower difference between the extreme summer and extreme winter case, then I guess cold air should be taken seriously. But when the difference between the ways of obtaining the cold air and inducing it into your engine yield almost the same results at speed, then what should you do? Who knows…
But maybe you could get a head start by using my write up! Enjoy and feel free to comment or add variables or conclusions that I have left out.
-Raceen
str8ridin
Old Jan 12, 2003 | 11:23 AM
Stillnmax's Avatar
youve been corrected.
Old Jan 12, 2003 | 11:25 AM
Kolyan's Avatar
I am not a pro here, i am just connecting what i read so far on this forum.
If Pop Chargers let more air into the engine (which is good), why there is a low-end loss of power then?
Old Jan 12, 2003 | 11:32 AM
Vyrus's Avatar
Who says there's a low end power loss? CAI owners?
Think of it this way: with the OEM setup, all of the air that goes into the TB comes from the OEM piping, which is restrictive and muffled, but nonetheless comes from outside the engine bay. With a hybrid or pop-charger, the air that goes into the TB, when it is stationary, comes from everywhere (including the engine HOT) hence it is much more free-flowing. Once you're moving, that loss is gone because the outside air (which we will assume is cooler because of its velocity) is rushing into the engine bay.
-Cyrus
Old Jan 12, 2003 | 11:44 AM
Kolyan's Avatar
"...Once you're moving, that loss is gone because the outside air"
Isn't that the so called "low-end power" loss that everyone seems to complain about?
Old Jan 12, 2003 | 11:47 AM
Vyrus's Avatar
No the low end loss is really off the line. When you're initially moving, and the air is mainly sucked up from the engine bay. Generally the added power from a hybrid negates this loss.
-Cyrus
Old Jan 12, 2003 | 12:07 PM
Kolyan's Avatar
good enough. maybe you can also answer another question without me posting another thread. i am wondering about AGX struts...How is the ride on setting 1 (softest) compare to stock SE set-up?
Old Jan 12, 2003 | 12:29 PM
Vyrus's Avatar
It depends on if you are getting lowering springs. But if you plan to keep SE springs and use AGXs on their softest setting, it will be very comparable to the SE ride, possibly a little harsher, but nothing close to the ride of a lowered car.
-Cyrus
Old Jan 12, 2003 | 01:32 PM
Kolyan's Avatar
thank's, i'll put that mod on my list. i am planning on keeping the stock springs and get AGXs. i like the fact that they are adjustable.
Old Jan 12, 2003 | 02:58 PM
ThurzNite's Avatar
well, if you've got an intake, it's very likely you have another mod that works with it...such as headers, Y, B, catback...put them all together and you'll see the difference an intake makes.
My personal preference is PR Cai. I prefer low end grunt.
Jae
Old Jan 12, 2003 | 03:13 PM
krismax's Avatar
Father of the 00 VI
Does your stock intake suck the hood down my stillen does.And i have a multichecker it tells my air intake temps at all times it stays the same as the temp outside 90% of time when i get my fan switch hooked up the other 10% will be gone.I felt a huge gain from idle to redline ,the greedy was installed first.I have a friend that works at a dealership he thinks with a without a intake its night and day.
maxima297
Sep 30, 2015 03:32 PM
MichMaxFan
Sep 30, 2015 09:18 AM
Socalstillen
Sep 26, 2015 12:01 PM
