steering wheel problem?
Old Jan 12, 2003 | 06:19 PM
stephenlc's Avatar
Umm it seems when I barely push on the gas, like below 2500 rpm, my sterrign wheel shakes back and forth. Like moves left and right very slowely. When I speed up, it shakes less and is not as noticiable. Is this an alignment problem. I read somewhere if you burn out it will allign your tires a little. I did that, and it went away for a little while but came back..
Old Jan 12, 2003 | 06:47 PM
Ramius83
It can be a few things. You may need an alignment, tires may be bad, bent rims, improper tire inflation (wrong psi), etc.
Old Jan 12, 2003 | 09:49 PM
Velcro's Avatar
Re: steering wheel problem?
drove a 93 maxima with that exact same problem it was found out later that there was a cut tire in the front. Check the roundness of your front tires b4 spending alot of money on front end work.
Old Jan 13, 2003 | 05:01 AM
stephenlc's Avatar
Ya let me go check my tires, probally that, maybe I puntured one, doh!!!
Old Jan 13, 2003 | 05:50 AM
njmaxseltd's Avatar
Definately sounds like a tire problem. Rotate front to back and see if it goes away. You could have some tread squirm going on. Thats not good.
MAXSE5SPD
Sep 17, 2022 04:00 AM
trasmadean
Feb 1, 2017 08:20 PM
intimidator
Sep 5, 2015 07:23 PM
maximusrising
Sep 2, 2015 09:55 AM
tnewbs
Aug 28, 2015 10:15 AM
